Will there be a problem...
Old Aug 9, 2003 | 04:58 PM
Reddragon91's Avatar
Car: 1991 RS
Engine: 87' 350 TPI
Transmission: 700
...with any of the headers on the market if you have D-shaped exhaust ports. I have ZZ4 heads waiting for me to put on but I want the put the haeders on at the same time. I was wondering if I can get any kind of header or will only a certain size fit. I have heard that the Hooker 2055's are a good header for the money and so are the ones from SLP (correct me if I'm wrong) but will there be a problem with the ZZ4 heads. If it helps, I have a 350 tpi (MAF type), new cat with flowmaster 3 inch exhaust,waiting in the garage to be put on are the ZZ4 heads, SLP runners, and 24# injectors. Thanks in advance. Reddragon91
Old Aug 10, 2003 | 10:18 PM
LastViceRS's Avatar
Car: '91 RS
Engine: LO3, For now...
OK, forgive my ignorance of some aftermarket parts - the D-shaped ports have an "arch" on the top of the port, right? If so, I can tell you that the 1-3/4" SLPs have this shape. Mine fit well, don't leak and weren't that hard to install. They aren't cheap, however, so the 2055s will beat them in that category. Sorry, I don't know about the fit of the 2055s. Hope my rambling is of some value.
Old Aug 11, 2003 | 12:57 AM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
My Edelbrocks fit perfectly on my ZZ4 heads. No problems or leaks at all. I think pretty much any header will work fine on D-port heads.
barbiek9
Sep 3, 2002 04:24 PM
FLYNLOW92rs
Aug 30, 2002 12:17 AM
Philou
Aug 18, 2002 01:29 PM
Blaze of Glory
Nov 20, 2001 10:18 AM
