ground clearance probs with 4" Mufflex on lowered car
Old Sep 10, 2003 | 10:27 AM
coprunr's Avatar
Car: 89 S10 Blazer
Engine: 4.3
will the Mufflex 4" Cat back give me major ground clearance problems on a car with 2" drop in front and 1 1/2" drop in rear?
Old Sep 10, 2003 | 11:12 AM
wingnut's Avatar
Car: '91 Firebird
Engine: 408 SBC
The 4" pipe itself won't be a ground clearance issue if it is properly installed. However, if you run the 3" Y-Pipe (made by Flowmaster) that Mufflex sells, you will be scraping ground whenever you hit a dip in the road. That is the least of your problems if you plan on running long tube headers, as the collectors will be the lowest point of the exhaust system.
I have Hooker Super Comp (long tube) headers, 3" Y-Pipe & 4" exhaust (from Mufflex). My car is not lowered and my header collectors still bottom out on some roads. The Y-Pipe tucks up nicely to the undercarriage if you take your time and rotate the different segments of pipe until you get the best fit. The point under your tranny crossmember is the limiting factor - some people grind clearance in the crossmember, I didn't. The 4" pipe is a non-factor as far as ground clearance.
Old Sep 10, 2003 | 11:32 AM
coprunr's Avatar
Car: 89 S10 Blazer
Engine: 4.3
i am planning on running 1 3/4" shorty headers if i can find some i like ....if i find some with a matching y-pipe will i be able to tuck the y -pipe since the collectors will be mounted higher in the chassis?
Old Sep 10, 2003 | 02:47 PM
wingnut's Avatar
Car: '91 Firebird
Engine: 408 SBC
I'm not sure what's available in regards to mating shorty headers to the Mufflex cat-back system. I'm sure that someone here can help you out though.
Old Sep 10, 2003 | 03:47 PM
Marc 85Z28's Avatar
I'll help I'm currently running SLPs 1 3/4" shorty headers to a custom 2.5" dual pipe setup along factory Y-pipe routing connecting to a 4" Mufflex. With the pictured wheel/tire combo and a 1.25" lowering at all 4 corners I have better ground clearance with this setup than I did with my SLP piping and Hooker 3". Just take the time to install the system and like wingnut said, keep rotating the pipes until it tucks up nicely. I guess I need to update my sig
Old Sep 10, 2003 | 04:07 PM
coprunr's Avatar
Car: 89 S10 Blazer
Engine: 4.3
cool...thanks for the advice fellas....one other question...are the SLP 1 3/4" rearlly worth $500?
Old Sep 10, 2003 | 04:59 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Yeah, when installing the mufflex system and going with what ever header and y-pipe configuration, I cannot stress how important it is to take your time. From what I have told people in the past and seen, the mufflex system is not a bolt in system. It's close but more work needs to be done. If you take your time, cut a few pipes, and use custom hangers, you can make if fit "very" tight. Mine is tucked so far up that you cannot even tell I have a 4 inch sewer tube under the car until you get under the car.
Old Sep 10, 2003 | 05:01 PM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
YES
Old Sep 11, 2003 | 10:55 AM
Marc 85Z28's Avatar
No. That's why I bought mine used for only $200 including Y-pipe
Old Sep 14, 2003 | 01:55 PM
89Thrd-GenGTA's Avatar
acually how loud is this system? i have a flowmaster on there now (came with car) and i was thinking borla. A sound clip maybe? thanks in advance
1992 Trans Am
May 10, 2023 07:19 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Reborn756
Sep 4, 2015 03:42 AM
kah992
Aug 19, 2015 02:55 PM
