Will I pass emmissions with this setup?
Car: Camaro RS
Engine: 305ci TBI
Transmission: TH-700R4
Friday Im going to put on my headman headers/ y-pipe and 3"x14" cat. Ima rip out the A.I.R. tubes, but can i still pass emmissions? Thanx
SSBO
SSBO
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You should pass without any problems. Make sure your car is nice and hot before you go but you shouldn't have any problems as long as you have a cat. Now as for a visual inspection I have no idea. We just have sniffer here.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
You should keep the air tubes connected to the cat so your converter will work in a 3-way manner. Else you'll prolly fail.
The air tubes to your headers/manifolds are for warm up closed loop purposes only, and shouldn't effect most modern emissions tests.
And a lot of new cars don't have air tubes on the manifolds, nor did some F-body's (pulsair) and I doubt your inspector knows which did and didn't.
-- Joe
-- Joe
Car: '90 RS
Engine: 377 LSX
You still should pass. I know plenty of people that have heads and cammed LO3's with EGR delete and a horrible tune that have passed. The only thing they had was a new cat.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
You do need air to the cat for a 3-way cat to work properly though. A 2-way cat will not pass emissions on a modern test.
-- Joe
-- Joe
Car: 05' GTO
Engine: 6.0L
Transmission: A4
I used to run a Catco hi-flow cat and it had the air tube on it but never used and well i passed with flyin colors. and the cat was the only thing i had on my car for emmissions controls. You can pass with just a cat and no air tubes hooked up.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
What was your specs?
My car ran 12.60 @ 110mph and I passed emissions better than a '03 civic with a 3-way cat.
-- Joe
Car: 05' GTO
Engine: 6.0L
Transmission: A4
read outs from NJ state inspection
NOx- standard is 1323, i passed with 1055
HC- standard is 173, i passed with 8
CO%- standard 1.63, i passed 0.00
that was this yrs.
with the edelbrock carb.
this is last yrs with a non-cc q-jet
NOx- standard is 1323, i passed with 219
HC- standard is 173, i passed with 11
CO%- standard is 1.63, i passed with 0.07
thats with just a hiflow cat, nothing else emmisions related
that was this yrs.
Transmission: 4L80E/4L80E
There are a couple of issues here:
1) Functional. That's mostly what's being discussed here. The cat will work better with the A.I.R., no doubt about that. I see some people saying they passed without A.I.R. who have older cars - the standards do tighten with later years, so caution advised there.
2) Visual. A lot of places require the system for visual inspection. Even if the system isn't needed to pass sniffer, it may have to be there for this little technicality. Since you're running an open element air cleaner, I'd guess this isn't an issue for you. But, for many of us, it is.
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
Wow, Im not sure about in the US. But NO ONE checks for emissions where I live. sorry to hear about the problems you all have from this
Car: '90 RS
Engine: 377 LSX
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I got a high-flow (flowmaster suposedly) aluminized cat today with NO air pipe. Once I verify its origins better, I might bolt it on my car to see how it works.. I'll throw it on the emissions dyno and let you guys no the difference compared to my air cat...
-- Joe
-- Joe
Doobie52
Sep 11, 2015 06:19 PM
