Tranny crossmember problem with true duals.
Old Oct 31, 2003 | 10:44 AM
joshwilson3's Avatar
Old Oct 31, 2003 | 10:58 AM
88Spinner's Avatar
Car: 88camaro
Engine: 355
Transmission: th350
good luck
Old Oct 31, 2003 | 03:51 PM
1989RS's Avatar
Car: 1989 rs camaro, 1990 jeep wrangler, 1995 eagle talon tsi awd
Engine: nothing right now
Transmission: j.w. performance th350 3500 10" stall... soon to be t56
look under your car at the framerails ant the tranny fluid pan and you will see why nobody makes one for automatics, there is about 1 1/2 inches of clearance to put your crossmember and pipes, i dont think that is happening unless you move the whole subframe(not happening) so, if you have anautomatic, you are screwed into going under the crossmember. look in the longtube f.a.q at the beginning of this forum to see how to go under the crossmember
p.s. the pic you put up of the underside is not an f body, it is a g body, which has a full frame and does not have to worry about subframes
Old Oct 31, 2003 | 04:50 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
the car shown in the pic has a full frame
a crossmember like that aint happening in an f body
Old Oct 31, 2003 | 07:09 PM
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
Transmission: TH-350
That's why I built my own.
Old Oct 31, 2003 | 07:12 PM
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
Damn that's a small *** pic! lol Ok how do you re-size it?
Old Oct 31, 2003 | 07:24 PM
Jack G Jr's Avatar
Hey you check over at www.manicmotor.com they say they have crossmember that will work with dual exhaust.It's worth a try
Old Nov 1, 2003 | 12:48 AM
Old Nov 1, 2003 | 01:59 AM
biff85ta's Avatar
Car: 04 Vette
Hey dude you can adjust things so as not to lose all your ground clearance. Where is ****** anyway? If you aren't too far from ******** maybe you can make it to a club meeting sometime and I will show you my setup.
Last edited by biff85ta; Apr 24, 2012 at 10:39 AM. Reason: joshwilson3 asked me too....
Old Nov 1, 2003 | 02:09 AM
Old Nov 1, 2003 | 04:09 AM
biff85ta's Avatar
Car: 04 Vette
Check the website in my sig. We are meeting today at beech bend but the Dec meeting is still unanouced for now as we have not decided on a spot to meet for it. Stop by on the board and introduce your self.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
downsouthboy
Aug 29, 2015 11:29 AM
theurge
Aug 21, 2015 12:46 PM
hokis
Aug 9, 2015 03:57 PM
