EGR and AIR
Old Dec 8, 2003 | 10:18 AM
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
EGR and AIR
Hi,
What is EGR? Is it the same thing as AIR?
Old Dec 8, 2003 | 10:58 AM
Stokdd's Avatar
Car: Yellow '92 Formula
Transmission: A4
EGR means Exhaust Gas Recirculation. Recycles exhaust gas back into the intake. It's purely for emmissions.
Old Dec 8, 2003 | 11:55 AM
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
Where can I see if the car has EGR? Is it something on the manifolds?
Old Dec 8, 2003 | 03:58 PM
Z dude's Avatar
Car: 1991 Z-28
Engine: TPI
Transmission: 5-speed Rear:3.73
its a valve on your intake manifold ,what do you have for a car,year,motor etc. ??
Old Dec 10, 2003 | 11:03 AM
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
EGR
I have a TA 85 305 lg4
Old Dec 16, 2003 | 10:44 AM
CbrasTsteLkChk's Avatar
Car: '84 Camaro SC/ I-ROC Body Conversio
Engine: Rebuilt 350 5.7L, Edelbrock 750cfm
Transmission: Re-built 700-R4
Axle/Gears: Moser, 3.73
I'm an emissions inspector -- with a gutted CAT!! hehehe
EGR (Exhaust Gas Reciculation) - it's a valve with a diaphragm that opens and closes and runs on a ported signal from the intake. It takes inert gas that's already been cumbsted in the chamber an pours a little bit back into the intake manifold to be burned up and basically "waters down the whiskey" and cools off the combustion temp. therefore reducing Oxides of Nitrogen. On carb. engines it's in the very back inbetween the air cleaner and the rotor tucked way up under there. It looks like a little pancake thingy.
AIR (Air injection Reaction) - your air pump (aka smog pump) pumps air into your CAT as well as the exhaust manifold to increase the temp. and help burn up the gases left over after the combustion process. Whenever you add air temp increases. Your AIR/PAIR/Smog Pump system consists of a diverter valve, checkk valve, and lines. Whenever you have a problem with backfiring 9 times out of 10 it's due to a bad diverter valve. The divereter valve acts as a one way street, allows air to go in and prevents hot exhaust gas from going back into the air pump. When you notice the hoses from your divereter valve and check valev burnt up, it's obviously not doing it's job allowing the exhaust gas back through and burns up the valves causing backfire
Hope that was of some asssitance.
Old Dec 16, 2003 | 10:52 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
sweet it sure helped me a lot. now how can i get rid of all that crap? anyone have a little tutorial?
Old Dec 16, 2003 | 11:11 AM
Well I'm not sure how you would take off the EGR unless you had like a flat plate built to bolt on to where it bolts on to the intake manifold and then block up the hole it pulls echaust in from.
And you could take off the air pump and cut off the air tube to your CAT. You would probably have to get a new CAT and you would probably need to get new exhaust manifolds.
I'm really not sure how would else you would go about it.
Old Dec 16, 2003 | 11:23 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
well as we speak im in the process of gutting my cat. but i want to take off the EGR, AIR system, and all the other crap like my smog pump etc. anyone know how to do it best?
btw check out my cat gutter 3000!
Old Dec 16, 2003 | 11:35 AM
WHOA! SWEET! You make that?
Ya know if you take a hack saw and make the end into a point and you ram it intot he CAT it'll be a lot easier than suing that blunt end. Just an idea
Old Dec 16, 2003 | 01:02 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
yea good point. the reason this works so well is because its off center so it wobbles around and breaks everything up and i took the end to my bench grinder and gave it a little edge.
Old Dec 16, 2003 | 03:39 PM
nice... now let it eat and lemme know how it works out.
Old Dec 16, 2003 | 09:59 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
o yea! the cat is gutted and the friggin exhaust sounds 5X meaner than before. i hate cats! i just got to get the y pipe welded to the cat again to make it look stock and get rid of that little leak i have. it was defenitly worth the day i put into it and the money i had to spend on new tools!
Old Dec 18, 2003 | 01:02 PM
kanuck's Avatar
Car: 1982 Trans Am
Engine: 350 Crate
Transmission: TH350
I fabricated a steel block off plate for my EGR and removed it. Used a new gasket and the plate and it works great. Didn't have to retard my timing either. I don't have a computer though, not sure if it would throw a code if you did as the computer actuates the vacuum for the EGR normally.
Removing EGR won't make your car faster either, it doesn't operate at WOT. I removed it to look cleaner under the hood.
You can also buy block off plates through...Summit I think.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
rjcme
Sep 5, 2015 01:23 PM
scotrans am
Sep 5, 2015 04:26 AM
