SLP tri-y headers L98 angle plug heads
Car: 1984 Z28
Engine: L69 305 HO
Transmission: 5 speed manual
Axle/Gears: Auburn pro yukon 3.73 gears and axl
I was wondering if the slp tri-y headers will fit 84 Z28 305 L69 with L98 alluminum angle plug heads.SLP says their present models DO NOT fit these heads.I have called 1 time and e-mailed 2 times to make sure but have not asked about tri-ys .If any one can help it would be greatly appreciated......Thanx......... 65 panhed.
Car: 84 Z28
Engine: 72 350 .030 over
Transmission: 89 WC T-5
I am running the SLP 1 3/4 coated, non AIR headers on my 350 with the Aluminum L98 heads. its a little tough to get at the plugs but they will work.
Car: Z/28
Engine: 355
Transmission: Turbo 400
It will fit just fine. I originally ran a 350 with L98 Alum angle plug heads with SLP Tri-Y headers with no problem at all. Its a nice setup. You will need a shortened spark plug socket to get to some of the plugs but its not bad at all.
Car: 1984 Z28
Engine: L69 305 HO
Yes there are a lot of concerns with these headers but they are really supposed to run well and they will keep me smog legal.....
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: what about the D port exhaust
Originally posted by SLP-GTA
I heard the SLP headers dont match the D heads
Car: 1984 Z28
Engine: L69 305 HO
Hmmm no more posts.......any headers to fit L98s? It looks like SLP 1a3/4 and see what happens......
Car: 1984 Z28
Engine: L69 305 HO
Originally posted by thecoolone
you must be new lol.
Hooker 2055's.
Hooker 2055's.
yeah thats obvious Imanewguy but hooker says no way on the 2055s dude........he called me dude,......dude......thanx........I will try to be less obvious from now on
Car: 1984 Z28
Engine: L69 305 HO
sratches head......oooooook
If I gave misinformation, sorry I'll try to only answer more, more obvious q's.
yeah I really wanted to use a good proven header in the smog legal shorty style without spending a thousand bucks.I asked about grinding the header ports but that wouldn't work either.I guess that I will call hooker again, their gonna know me on a 1st name basis when I'm through............thanx for input
Car: 1989 Firebird Formula
Engine: 305 TBI
Axle/Gears: 3.08
Thats strange . I have hooker 2055s and aluminum L98 heads . I measured the port on the heads and the ones on the headers and the ports on the headers are bigger than the ports on the heads length and width wize .
Car: 1984 Z28
Engine: L69 305 HO
well I guess I'm gonna go with tri yz and see what happens..Thanx to all for the input and I will keep everyone up to date on this project. From stock L69 to ZZ4 heads with 55cc chambers comp cams XE262 or XE268 weiand action plus 8000 with holley 650 spreadbore 6210 and msd 6AL box with msd billet distributor and coil...........Please join me in a silent prayer........
evilstuie
Feb 28, 2016 03:33 PM
