Hooker 2055 question
Old Jan 1, 2004 | 10:54 PM
ksrammstein's Avatar
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
Does the hooker 2055 fit on no TPI systems. I want to put the system(headers and Y pipe) on my 1984 Trans Am. My trans am has a quadrajet. What is so different about the TPI? Will it fit on my car? Please any help would be appretiated.
Old Jan 2, 2004 | 12:05 AM
25THRSS's Avatar
To answer your question, yes they will fit. If you do a search you will find out the details you want to know.
Old Jan 2, 2004 | 12:14 AM
Then why do they say it only works from 1986 and up. Will I run into some unexpected problems or is hooker just being an ***?
Old Jan 2, 2004 | 02:51 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
No, they're responding to customers who have been asses.
They make the headers to bolt directly to factory systems of the applications listed. The headers will, however, bolt to any factory SBC engine, will route properly in the frame, and if you get replacement parts for the same application they list, will bolt to the cat & cat back.
I had to reroute the A.I.R. on the driver's side, since the factory system has the hose routed over the front of the engine with the check valve inlet pointed forward. That's the only installation issue I had.
Old Jan 2, 2004 | 03:36 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
II had to reroute the A.I.R. on the driver's side, since the factory system has the hose routed over the front of the engine with the check valve inlet pointed forward. That's the only installation issue I had.
That should be the only problem.
Old Jan 3, 2004 | 12:06 AM
I was under the impression that the 2055s didn't come with AIR. I have seen pictures of them, fresh out of the box, with out them. Am I missing something? Considering I just ordered them from ACS it would be a good thing to know.
Old Jan 3, 2004 | 12:21 AM
25THRSS's Avatar
they DO come with air
Old Jan 3, 2004 | 12:22 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
billybob6110
Sep 24, 2016 09:50 AM
formula_novice
Sep 5, 2015 03:58 AM
tricky1
Aug 23, 2015 01:17 PM
redmaroz
Aug 16, 2015 11:40 PM
