how to set up a custom dual exhaust, which is better?
Old Jan 13, 2004 | 08:44 PM
ChevyCamaro4lif's Avatar
alright so im planning on welding together my own header back exhaust system after i decide on my long tubes.
whats the difference (sound, performance, etc.) between an H-pipe and an X-pipe?
which of the following muffs would sound much more like a high performance race car (loud deep roar at full throttle, nice rumble at idle) flowmaster 40 series or dynomax welded ultra flow oval?
what is the size of the collector flange on the hooker supercomp long tubes?
Old Jan 13, 2004 | 09:12 PM
ScreaminDeamin85Z's Avatar
I have never heard an x-pipe so i couldn't tell you the difference, but alot of the sound comes from whats done to the motor(compression, cam size....) the size of the collector should be 3"
Old Jan 14, 2004 | 11:38 AM
unknown_host's Avatar
Car: 1989 Iroc Z L98
X pipe quiets an exhaust down a lot, not sure about an H pipe but I would imagine it has the same effect.
Old Jan 14, 2004 | 12:05 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
the X pipe is the prefered way to go, it flows and scavages better. that being said, and H pipe, or some kind of cross over, is much better than having seperated duals.
Old Jan 14, 2004 | 01:38 PM
if i were to do the instal of an x pipe, would it interfere with a T56?(this is my next project after exhaust.
Old Jan 14, 2004 | 02:06 PM
Dewey316's Avatar
Car: 1990 Camaro RS
it can be done with some effort, and fab work. i have a good friend who is running long tubes, x-pipe true duals, and a t56, all on a firebird that is lowered about 3"
but it took him alot of work to do it. and beleive it or not, the collectors on the headers are the LOWEST point of the whole system. you'll have to make a cross member for the tranny that will allow the pipes to run along side the transmision in the tranny tunnel, then locate the X just before the yoke, where there is more room due to the tailshaft.
i am probably not describing it very well, i will see if i can get pics from him.
Old Jan 14, 2004 | 02:16 PM
also, why would an h-pipe or some sort of cross over be better than just seperate duals?
does anyone know what the sound difference of this set up would be than seperate duals?
Old Jan 14, 2004 | 02:46 PM
Better sound quality imo. I have dual 2 1/2" with an x pipe, and it sounds really mean WOT but fairly tame at idle. Also, the x pipe got rid of a lot of annoying pops and what not I was getting with single 3".
Dewey316's Avatar
Car: 1990 Camaro RS
the cross over is better becuase it maintains even pressure, and the pulses can scavage the other side of the system.
Old Jan 14, 2004 | 05:07 PM
Momar's Avatar
I had duals w/ a h pipe, and bullets, and my collector flanges were the lowest part of my system. I had a custom trans crossmember made when I went from auto to t56, and the shop that welded my crossmember for me decided it would be a good idea to cut the center out of my h pipe and weld caps on it to clear the tranny instead of checking w/ me. Right now the car is back appart, but my plan is to put an x pipe in it right were you said your friend has his in front of the yoke. If you take the time to get everything figured out you can have good ground clearance.
Ben
customblackbird
Aug 15, 2021 10:16 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
beastin91rs
Oct 9, 2015 07:38 AM
Dialed_In
Aug 20, 2015 01:45 PM
kah992
Aug 19, 2015 02:55 PM
