Shorty Headers w/ Y pipe?
Old Feb 15, 2004 | 08:32 PM
70BuickSleeper's Avatar
Car: 84 Z28
Engine: 305 HO
I have an 84 z28 305 HO and want a set of shorty headers with a y pipe to go to the factory cat. I would like to know which system you think is the best for performance, quality, and the best bang for the buck. Thanks
Old Feb 16, 2004 | 12:22 AM
25THRSS's Avatar
check out the sticky at the top of the page
Old Feb 16, 2004 | 09:51 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Shorty Headers w/ Y pipe?
Try a seach under "best exhaust" or "best headers" and you will get enough stuff to read for a year. You should have your answer in a few hours of reading.
Old Feb 16, 2004 | 01:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
As far as I know, Edelbrock is the only one to fill that bill http://store.summitracing.com/partde...art=EDL%2D6874 .
That's a different answer. A system for '86-'90 TPI single-cat from headers to rear bumper is better than anything you could get that goes to the factory cat.
Old Feb 17, 2004 | 07:47 AM
Car: 84 Z28
Engine: 305 HO
Is the hooker 2055 w/ the y pipe going to connect to my factory cat on the 84 z28 ho without having to fabricate anything? Also, Im looking at the hooker cat back exhausts, the hooker website shows a 16822 for 83-85, and a 16823 for 86-92... There is a 60 dollar price difference between the two of them, what is the difference between them?
Old Feb 17, 2004 | 09:48 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
The differnces are usualy in the moutning flanges. They change from model to model. The heads and catbacks for out cars have pretty much the same size piping and routing but the flages to coonect to stock set-ups is what gives them different prices and part numbers.
Old Feb 17, 2004 | 03:28 PM
five7kid's Avatar
If you want a great flowing system, I'd suggest this (Summit p/n's): HOK-2055 Hooker headers with y-pipe, which is for the '86-'90 TPI single cat application; CTO-9118 Catco direct-fit cat for '86-'90 TPI single cat application; and the cat-back for the same application. This will all bolt together, will eliminate all of the year-specific factory system, and get you something that's emissions-legal, good-fitting, and good-performing.
There is nothing "magic" about the '84 HO system. The only things that could be "issues" for you are: The EFE valve is eliminated (that hasn't cause me any problems, though); and the driver's side A.I.R. check valve on the 2055's points to the rear instead of forward (I used a couple of 90 degree elbows & a chunk of pipe from Ace Hardware to turn it back around).
Old Feb 17, 2004 | 03:59 PM
Car: 84 Z28
Engine: 305 HO
Thanks for the help. I dont have air injection on my car anymore, so thats not a problem, does the 2055 have pipes welded on or just threaded holes? I guess it doesnt really matter because Ill cut them off and weld the whole closed. The camaro is just my daily driver, and want to do little work to it as possible... ie making parts for the exhaust... im lazy. besides, Im building my real car in my garage so thats where all the effort goes... 70 Buick Riviera, 455 Cubic Inch (7.5 L V8), 525 ft lbs torque, 400 horse (stock except for headers and dual 3 in mandrel custom exhaust). Peak torque around 3 grand... you gota love the low end torque. Its a shame that GM cant do that on low budget cars now a days... hahaha
Old Feb 17, 2004 | 04:33 PM
five7kid's Avatar
The A.I.R. tubes are welded onto the primaries of every aftermarket header, as far as I know.
Low-end torque on budget cars is what got us the 305.
LT1Formula
Oct 8, 2015 08:34 PM
Zell1luk
Sep 29, 2015 10:36 AM
