1 3/4 or 1 7/8?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: 1 3/4 or 1 7/8?
Originally posted by BWW
Which size headerwould be better for a supercharged engine with 460hp and 500 ft lbs?
Longtubes 1 3/4 with 3'' or 1 7/8 with3.5"
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Originally posted by 88IROC350TPI
1 7/8" headers are insane unless you are making some serious HP
I like the stepped header idea. Kooks makes custom stainless headers and can probably do a stepped 1 3/4" to 1 7/8" header.
You would more than likely be fine w/ 1 3/4" headers w/ a 450 rwhp supercharged motor.
Car: 89 Formula L98 power
Engine: '96 subaru, opposed 4banger
Transmission: TH700R4, subaru 4WD
Axle/Gears: 3.27, just works
1 3/4 are more than enough for motors pushing up to the 500+ range, if you run 1 7/8" primaries, you need flange adapters to bolt them up to small block heads. And if you ran the 1 7/8" headers your going to lose some velocity on the low end, hurting your low end torque, and you'll probably gain some on the top end, but they are probably over kill for that motor. I believe car craft or hotrod did an issue, that tested each type of headers, shorties, equal length, long tubes, tri y's, and anything in between, including different primary sizes, you may want to look for that one.
Car: 1989 Trans Am
Engine: 355 HSR
Yeah I saw that article and the 1 7/8" compared to the 1 3/4" picked more hp up top than it lost down low. Why would you need flange adapters to bolt them up??
What the article did prove about the added 1/4" was that it moved peak power up in the powerband by about 150 RPM. But the difference in the high end hp and low end torque was negligable IMO. What is 8 ft/lbs when you pick up 12 hp up top while moving the peaks up in the powerband? To me nothing.
The main issues is going to be finding a company that produces a set of 1 7/8" header, if the decision is made to go that way.
I am not going to argue w/ the overkill arguement though. I doubt the 1 3/4" would be that much of a restriciton. My point is that if he is referring to 460-500 rwhp, then I am pretty sure that he might net a few more hp out of the 1 7/8".
Car: 1989 Iroc Z L98
Supercharged, turbocharged and nitrous injected cars benefit from an overkill exhaust setup. Cylinder heads with 1:1 I/E ratio, 1.6 ratio rocker arms on the exhaust side and camshafts with 13* more duration on the exhaust side @.050 than on the intake. Go with the 1 7/8" headers, especially since you wont have to worry about any loss of low end torque. David Vizzard says that 100 hp nitrous jetting on an NOS kit came make as much as 190 horsepower with the right camshaft and exhaust setup
. Supreme Member
Car: 1989 Trans Am
Engine: 355 HSR
. Banned
You need an adapter for the 1 7/8" headers, because the primaries are too large, and the bolts would be smashing into the primary tubes. When you step up to a 1 7/8" primary over a 1 3/4", theres a flange adapater required, which relocates the bolt holes, to a more staggered fashion.
[For Sale] 1 3/4 budget LS swap headers NEW (CA)
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
