3rd to 4th Gen Borla tip swap?
Car: 90 RS
Engine: 355 ci L98
Transmission: G-force T5
I did a search and noticed that a few of you guys swapped the not-so-nice tips that come with a third gen Borla cat-back for a set off a fourth gen system. I (personally) don't like the standard third gen tips, but wasn't aware that I had any options. I know that they probably won't be perfectly straight or evenly spaced, as the Borla tips tend to be, but is it just a straight swap? Off with the old ones and on with the fourth gen's? It seems like all I need is the end (tip) section off the other system (right behind the last clamp) on either side. Is this correct? Or do I need the entire tailpipe-- behind the Y? This is something I'd really like to do, but I'm not too sure exactly what I need or where I can find it. Any help you guys can give me is really appreciated, especially if anyone knows where I can get what I need. Thanks
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: 3rd to 4th Gen Borla tip swap?
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
everybody says these tips are so ugly....well what the heck do they look like? I think they look great on paper, but so did communism.
Car: '90 RS
Engine: 377 LSX
Here is a bit better pic to show you what they look like from under the car
those tips do go well with your car, but they are a little different than the ones that come with the borla cat-back. The ones on the borla cat-back are slashed.
Car: '90 RS
Engine: 377 LSX
Car: 90 RS
Engine: 355 ci L98
I know that Borla makes plenty of tips. But, the problem with those is that the tips that come with the cat-back system are bent a specific way. Also, the passenger "tip" is not actually a tip. It has a flange at the beginning of it that bolts to the rest of the exhaust behind the restrictor plate. I THINK (not really sure) that I need specific tips to replace the ones I have...
Hey shifty....I saw the picture of the borla system in the new Jegs catalog. They had it as one of the features. I called them and they guy told me that the system hasn't changed at all. Where did you get your information that they changed the system?
Not to mention that borla has the old system on their webisite...and I would assume they would be the first to update
Car: '90 RS
Engine: 377 LSX
But I hope you are right....cuz if you are...consider the system sold
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
