SLP header flanges
Old Feb 29, 2004 | 01:16 PM
Brett H. - 89GTA's Avatar
Car: 1989 GTA
Engine: 5.7L
Axle/Gears: 3.27 BW 9-bolt
SLP header flanges
I bought some SLP 1 3/4" headers a couple of years ago...just now getting around to installing them. I noticed that the flanges for the center two tubes are off by about 1/16" compared to the flanges for the end tubes. On one of the headers the center flange is also at a slight angle (top to bottom) compared to the end flanges.
Will this misalignment be a problem? I was hoping that after torquing the center flange into place that the bolts would pull the flange flat against the head. The gaskets that came with the install kit are not going to be thick enough to take up all of the gap.
Old Feb 29, 2004 | 05:18 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: SLP header flanges
You should be able to just bolt them up and have thme go into place. I have read about other people having similar problems with SLP's. My flowtechs did the same thing but didn't bend as easy because the flange was connected to every primary.
By the way, where in SW ohio are you?
Old Feb 29, 2004 | 05:27 PM
Car: 1989 GTA
Engine: 5.7L
I'm in Englewood.
How much warpage did your Flowtechs have? Did you have trouble getting them to seal up?
Old Feb 29, 2004 | 05:53 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I'm in Englewood.
I know where that is and you are just north of here. I used the percy's dead soft aluminum gaskets that help fill the void. No leaks as of yet. Yours should still bolt up since the flanges are separate from each other. If you call the SLP tech line they will probably tell you the same thing. Lay them flat on something and see how far off they are? Anything within a half inch shouldn't cause any problems and they should bend easily into place.
Forgot to mention:
Check out www.daytonfbody.com
Old Feb 29, 2004 | 06:15 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
mine were also the same way....I think all the SLP's are just about the same with that problem since there isnt a flange going all the way across.....I also used the Percy gaskets and they fill what ever gap there was. makes it look like a whole flange but Im sure you can just cut the size you want and go with that.
Old Feb 29, 2004 | 06:28 PM
Car: 1989 GTA
Engine: 5.7L
1/2"???? If they were that far off I'd be chewing out SLP on the phone!
I had hoped with good gaskets they would draw up and seal...especially since the SLPs have separate flanges. I also considered doubling up on the gasket for the center tubes.
The flanges are off by about 1/16"...maybe a bit more on one side. Where did you get your Percy gaskets? How thick are they? How are their sealing characteristics compared to copper?
Old Feb 29, 2004 | 06:34 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I wanted to send them back but certain cercumstances prevented me from doing so. Anyways, They are about 3/8" think and are mutil layered. I got mine from jegs for about 35 bucks or so. They are not cheap but will never blow out, last a long time, conform to gaps and what not, and are re-usuable. At 1/16 off you will be fine and that tube should pull forward when you put them on. I would not sweat it at all.
Old Feb 29, 2004 | 06:36 PM
mine were not 1/2........
Heres the Percy's,,you can get them at AZ.....I tink they costed $37.00 the same as Jegs or Summit. I dont know anything about copper but SLP says not to use copper with their headers.
Old Feb 29, 2004 | 06:38 PM
heres another..the thickness should work for you.
Old Feb 29, 2004 | 07:51 PM
Car: 1989 GTA
Engine: 5.7L
Thanks for the help, guys...I'll order a set of them when I order a new fan switch to replace the one that broke when I pulled off the connector. It's always something...
Old Feb 29, 2004 | 07:54 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I broke the same thing so don't feel bad.
Old Feb 29, 2004 | 09:03 PM
firbird's Avatar
why would they say not to use copper on the slp's?? why would alum be ok and not copper?
Old Feb 29, 2004 | 09:13 PM
I have no idea, thats what they told me when I called them. I guess something about the stainless and copper? I dont know?
Old Mar 1, 2004 | 02:49 PM
Marc 85Z28's Avatar
Copper is fine. I use the SCE copper on mine and have had no problems with them.
Old Mar 1, 2004 | 05:29 PM
icecold's Avatar
Car: 1990 formula
Engine: 350 tpi supercharged
Transmission: 700 r4
i also used copper sce gaskets and could not get them to stop leaking.finally changed to the graphites slp sent with.
are the dead soft aluminums really 3/8 thick?was thinking of using them bit that would require more dimple to miss the stearing shaft and i cannot do that i dident like doing it the first time.
pete
Old Mar 1, 2004 | 07:17 PM
Car: 1989 GTA
Engine: 5.7L
In the picture that Wishmaster posted, the uncompressed gasket thickness looks to be a little less than the flange thickness of the header. On my SLPs, the flange thickness is 3/8". I would imagine that the compressed thickness will be quite a bit less than that. I'm willing to deal with a few header clearance issues if it means they don't leak. Once a header clearance issue is resolved it usually stays that way; header leaks seem to keep coming back like a bad penny.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
redformula88
Oct 14, 2015 06:08 PM
Nervous2
Oct 8, 2015 10:53 PM
alpine247
Sep 16, 2015 05:25 PM
89fast5oh
Sep 8, 2015 09:55 AM
