need help
Car: 1982 Firebird Trans Am
need help
i put my new hedman long tubes in only to find out that on both sides they have clearence problems. on the drivers side they contact the motor cross member/strut tower area. and on the passenger side they contact my fuel lines. i was wondering if any one else has had these problems and how they fixed them. i dont want to dent my headers if i can help it.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
How old are your motor mounts? If they are original, they could be really worn out, letting the engine sag down alot. Fresh ones might jack up the engine enough to solve your problem.
They can, i've heard of them sagging an inch or more. You gotta remember here, that they are supporting a 600lb block of metal, so it pushes down pretty hard on them.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by b82ta
do motor mounts really sag much. i heard that they dont sag much at all i could be wrong.
ill get new mounts prob. by next year but ill run the stock ones til then
do the poly mounts cause more vibration than the stock ones, since theyre stiffer?
Car: '90 RS
Engine: 377 LSX
