Cut out
Old Mar 28, 2004 | 08:29 PM
RebelTillDeath3's Avatar
Car: 92 Camaro
Cut out
Is there anyway I can install it without welding anything? Right now I'm looking at the Jegs and Summit cutouts for about $30.
Old Mar 29, 2004 | 01:42 PM
Car: 92 Camaro
Anyone?
Old Mar 29, 2004 | 01:48 PM
ll-84camaro-ll's Avatar
Car: 91 Z28
Transmission: 4l60e
you could prob make your pipe slip over it and then clamp it down but it would require alot of pressure on the clamp you best bet would be to weld it because i dont know how strong the hold would be with the clamp. i never tried using a clamp though anybody think that would work?
Old Mar 29, 2004 | 02:14 PM
Car: 92 Camaro
So the cutout should come a bit bigger than my exhaust pipe? Say I order a 2.5 cutout, should it slip over a 2.5 pipe? If so then all I'll do is put a bolt through it to hold it.
Old Mar 29, 2004 | 08:26 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
What you are seeing in Summit and Jegs are cutouts intended to be welding in. You could possibly make it fit over the pipe if you had the ends flared to an 2.5" Inside diameter on the cutout, and then slip it on both sides of part of the exhaust on the car which I am assumign is a 2.5" outside diameter. Trust me though you woudl really rather take it and have it welded in. Most exhaust shops will only charge you about $20 or so to weld in it...
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
gord327
Oct 3, 2015 01:25 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
