headers
Old Apr 13, 2004 | 08:30 PM
mmcdjs's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1 V6
headers
Hello! Can anyone tell me if the headers off of a 350 on an el camino will work in our cars?
Old Apr 13, 2004 | 09:45 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Shorties or long tube headers?
Old Apr 13, 2004 | 09:54 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Will they bolt to your motor, yes. Will they clear the firewall and underhood compartment, unlikely.
Old Apr 14, 2004 | 06:51 AM
mmcdjs's Avatar
Engine: 3.1 V6
they are long tube headers, going into 3" collectors.
Old Apr 14, 2004 | 07:19 AM
mmcdjs's Avatar
Engine: 3.1 V6
these look like them, but the tubes are not as long as these are...
Old Apr 14, 2004 | 09:17 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
No offense but all headers "look similar." You are going to have to just try and bolt them in. That is the only way to tell. Typically speeking any header not desinged to fit in a 3rd gen engine bay will not work.
Old Apr 14, 2004 | 09:26 AM
mmcdjs's Avatar
Engine: 3.1 V6
guess it was just wishful thinking then...I'll have to check and see if it'll work. thanks!
Old Apr 14, 2004 | 09:29 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
no they wont clear...... they'll smack into the firewall first, and even if they didnt, they try to exit where the "frame rails" are under the car.... not inside them, but in the same space as them.
Old Apr 14, 2004 | 09:39 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
i can speak from experience. i had an old 81 el camino and i took the headers off of that (longtubes) and they DID NOT hit the firewall. i did however, have to do little denting to the framerails underneath. the only problem i had with them was the ground clearance. they scraped like no other. now i did use them with factory engine mounts (rubber ones). i switched to solids for my new motor/project and they WILL NOT fit with the moroso solid mounts for our cars.
Old Apr 14, 2004 | 10:17 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
the ones i held up smacked the firewall.. *shrug*
Old Apr 14, 2004 | 01:33 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
where on the firewall did yours hit? like i said the ones i used only touched the frame rails underneath but i dented them in.
Old Apr 14, 2004 | 01:54 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
the lower part of the firewall, near where the trans tunnel curve is.
it was one of thoes "lets just try it" kind of things...
thinking about it, they could have been 1stgenfbody headers but i thought they were chevelle.... and chevelle = elky.
Old Apr 14, 2004 | 03:18 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
i guess it does depend on the year of the elky and the types longtube vs short. he obviously is using the longtubes but from what years. that will make the difference.
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
