Band clamp or what?
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Band clamp or what?
What can I use to seal where my exhaust joins together? its where one pipe slides into the other so the pipe diameter is not the same across...one is wider than the other. Do you think something like a 3" band clamp will seal it good enough? I dont want to weld it incase I ever have to take it apart.
Engine: 305TBI
Axle/Gears: B&W 9 Bolt 3.73
I hate U bolt clamps, ive broke one, striped another and i usually end up having to cut the pipe to get it apart. from what i understand band clamps are better-expensive but better if ya dont wanna weld-who wants to weld on a cat anyway lol.
but do the band clamps seal good enough to not let exhaust out. Where my pipes meets I have a leak and can hear the ticking ....and sometime the condensation comes out of it
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
As long as the two tubes fit fairly well, you should be ok. The stainless steel of the band is ductile enough that it will deform, allowing it to fit the two different size pipes. Of course, I wouldn't call it a perfect seal, since it is ungasketed, but I wouldn't call it a leak either.
anyone know where I can get them? I knowI can get them thru Jegs or Summit but anywhere else, so I dont have to pay the crazy shipping for such a small item...
Car: 1989 GTA
Engine: 5.7L
Axle/Gears: 3.27 BW 9-bolt
I'm dealing with the same issue with my Catco cat and SLP catalyst adapter; the slip fit has a lot of slop in it. I'm going to use a band clamp and see how that works out. I'm trying to find a local Walker exhaust distributor to get it from. If that doesn't pan out...hey, there's always something else I need from Jegs or Summit anyway...I'll just combine the order.
Engine: Many
Transmission: Quite a few
look at Jegs. Someone else just recently posted about the exact thing you need. they have pre-formed stainless band clamps that are formed to join a nominal pipe(for instance, 2.5"OD) to a swaged end pipe(like 2.625"), so its for exactly that purpose. I was doing the same thing on my Y pipe, and just got one in the mail for 2.25" pipe. should work out for you, search under exhaust clamp, can't miss it.
Elephantismo
Feb 13, 2019 12:51 AM
no green
Jan 9, 2016 09:22 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
83 Crossfire TA
Sep 18, 2015 12:01 PM
