Flowtech Headers
Old May 18, 2004 | 09:07 PM
SiLeNT-T's Avatar
Car: '88 Camaro, 91 S10
Engine: Camaro has 355 TBI, S10 has 2.5L TBI
Transmission: Camaro has a TCI 700R4, S10 has 5-speed Manual
Flowtech Headers
http://www.yearone.com/serverfiles/f...ain2.asp?cat=G
Anyone use these, have used them, or know anybody that has?
I'm considering getting them for the 355 in my 88 Camaro. I'm planning on eliminating the AIR system and these are the only headers that I can find that stand a chance at clearing my Moroso 7-Quart oil pan (kicked out sump). My only other alternative (that I can think of) is to go back to factory manifolds, and I don't want to do that.
Any help would be appreciated, thanks.
Old May 18, 2004 | 10:19 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I have them and I got mine on sale coated from yearOne for about $400. I wish I would have not bought them. The quality is fine but the durabilty stinks. They were slightly warped at the head whcih i cured with thick gaskets. To this day I have yet to get the collectors to seal since they are so thin. I can't wait to get rid of them. Most shorty headers should yield the same clearance around the area you are concerned about.
Old May 22, 2004 | 10:47 AM
5.7Camaroboy's Avatar
Car: 85Z28
Engine: TPI355,383LT4
Transmission: 700-R4,T-56
flotech sucks i took mine off and i am now currently putting on heddman long tubes ceramic coated my flotechs warped on the flange slighty and i had a gasket blow out like every week...
Old May 22, 2004 | 09:11 PM
onebinky's Avatar
I had them for 3000 miles, and gave them to my brother. The collector gaskets leaked,and like shifty I couldn't get them to seal properly. Where the primaries came through the mounting flange was uneven. I was very surprised that they sealed without issue. When I removed them though, the rear gasket on the passenger side did have a burn mark on it like it was starting to break thru.
Fitment was excellent though, really didn't have to modify anything to mount them up. Just had to unbolt the trans crossmember and drop it down an inch or so to get the headers to clear the bellhousing for install.
My hedman LT's are a completely different story though... Took quite a bit of work getting them in.
Old May 26, 2004 | 09:56 PM
Car: 85Z28
I feel ya on the heddman longtubes
Old May 26, 2004 | 10:53 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I had to notch the frame on the passenger side to fit those things on my old firebird. Wouldn't buy them again (only did the first time because they were the cheapest ones)...
Old May 31, 2004 | 09:09 AM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Well just a few things to know, you'll need to jack the engine on the passenger side to fit the header in and definately use double gaskets at the collector, maybe triple.
Old May 31, 2004 | 09:26 AM
84firebird383's Avatar
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
you might want to switch to the moroso 6qt pan that was inteded for the 3rd gens. thats what i did, you can use same pick up tube, all you have to do is swap pans.
Old May 31, 2004 | 09:36 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
I have the creamic coated shorties and I have not had any problems with mine. They didn't slow my car down one bit compared to the old dynomax shorties I used to have. Mine also dropped right in with no problems. They still looked very nice after a bunch of driving also.
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
