Plug for O2 sensor bung/JB Weld
Old May 20, 2004 | 12:12 AM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
I was wondering if what could be used to plug the 02 sensor bung (beside an old o2 sensor). Also, does JB weld stand up to the temps on exhaust manifolds?
Old May 20, 2004 | 12:35 AM
Z28GEN3's Avatar
Engine: 305TBI
Axle/Gears: B&W 9 Bolt 3.73
jegs or summit sell plugs to plug 'em up. think thats what youll need, or if you can find a bolt with the same thread pattern you could use that, ive looked around and havent had any luck. Im not sure about the JB weld, im thinking NO but it might work.
http://www.jegs.com/cgi-bin/ncommerc...89&prmenbr=361
Old May 20, 2004 | 12:46 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
An old spark plug.
Old May 20, 2004 | 09:00 AM
davehamilton's Avatar
we carry them for $6 and $2 shipping ( o2 bunghole plugs)
Old May 20, 2004 | 09:04 AM
Oh!, I just saw you were in Houston, So r we so no shipping needed!!!
Old May 20, 2004 | 09:05 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
JB weld will melt if you put it in there. Just buy the 02 plug sold at any parts store.
Old May 20, 2004 | 10:38 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Wouldn't just an old bolt fit? Or maybe a pipe plug? Or maybe the same kinda plug you use to block the AIR holes on your manifolds (obviously larger though)? All of those won't cost more than 0.25 at a hardware store
Old May 20, 2004 | 10:52 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
You can do that but an 02 plug won't stick into the exhaust flow causing the bolt to get super hot and corrode or having it affect collector flow.
Old May 20, 2004 | 11:33 PM
JRoy91RS's Avatar
Engine: 355
Thanks Dave! I may be paying you a visit this week!
Old May 21, 2004 | 08:47 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
just to note:
YOU CAN NOT USE JB WELD ON EXHAUST.
it melts.
i tried telling my dad this when he cracked the manifold flange on his spitfire.
he did it anyway.
it smoked, it changed color, and it kinda melted.
he ended up buying a header.(hehe, its funny to say header instead of headers)
basicly, dont use JB weld on anything that goes over 300*....
Old May 22, 2004 | 09:18 PM
onebinky's Avatar
JB weld is just a 2 part plastic epoxy. What about just a brass plug like you would find in the plumbing section at the local hardware store? Brass stands up to pretty high heat. Only downside there is that you're mating two dissimilar metals.
92firebirdguy
Sep 1, 2016 07:53 AM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
tattmann
Sep 27, 2015 05:20 PM
