My new dual setup
Old Jun 6, 2004 | 08:57 PM
onebinky's Avatar
My new dual setup
We finished it today. This one took probably 4 hours total to do, so it wasn't bad. It sounds nice too, although it's a bit quiter than I'm used to. It has that nice rumble, but the exhaust is so quiet you can hear all the air rushing out of the tailpipes at idle.
It's dual edelbrock stainless 3 chambers, with side exit right in front of the rear tires. It's 2.5" all the way back, and we still need to make the H-Pipe. I'm thinking I'll use oval tubing for that to maintain ground clearance. As it sits right now, I still have 4.75" at the lowest point. Might scrape on a tall speedbump, but I think I'll be fine.
My dad also got the idea to make custom "mandrel" bends to go around the frame by the trans. Turned out pretty good. I notched V's in the tubing at the angle needed, used a hammer to collapse the V on itself, and then he welded it all up. I'll post a pic of that too.
All in all, I'm only out $73 dollars since I already had the pipe and got a good deal on the muffs.
Old Jun 6, 2004 | 08:58 PM
onebinky's Avatar
Old Jun 6, 2004 | 08:59 PM
onebinky's Avatar
I'll add these pics to the dual sticky when I get a chance.
Those edelbrocks are only 3.5" thick, BTW. That's the main reason I went with them.
Old Jun 6, 2004 | 09:01 PM
onebinky's Avatar
Third and last.
Old Jun 6, 2004 | 10:14 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Any pics of it on the ground? Looks like it might be a bit low.
Old Jun 7, 2004 | 02:00 AM
stiers's Avatar
I would be worried about ground clearance with that setup..how much room do you have when it is on the ground.
Oh and get rid of that POS Fram filter, they are the worst filters ever designed.
Old Jun 7, 2004 | 11:11 AM
onebinky's Avatar
Just as low as you see it on the ramps, it's fully resting on the suspension. Like I said before, I have almost a full 5" clearance. No issues pulling into driveways straight, but I have yet to do speedbumps.
I don't know if I'd call FRAM the worst filter designed, but they're definately not the best. The big fault in them, the check valve, we don't have to worry about because gravity keeps the oil in the filter while the car is off. Since I can't get Delco's around here anymore, I'm searching for a new favorite. The ways things have been going with all the mods, I've done about 5 oil changes in 2500 miles.
Old Jun 9, 2004 | 04:14 PM
iceman02's Avatar
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
Hey that's really similar to my plan.... except I will use the Spintech 2 1/4" thick low profile mufflers..... one under each floor pan kind of like that.
Old Jun 9, 2004 | 04:34 PM
germ83's Avatar
Car: 1984 Z28
Engine: 305ci
Just wondering, where did you get the ramps?? that you put your car on? (dont know wha the yare called.) Stands??
Anyway, where you get them, and how much are they?
Old Jun 9, 2004 | 05:02 PM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
I would.
I've been running the K&N's on my car and they rock. I rum Mobil 1's on my truck and Napa Gold (Wickes) in my other cars. All of the cars have Mobil 1 in them.
That exhaust wouldn't work for me, my subframes are in the way. It looks good though, if there is some clearance.
Old Jun 9, 2004 | 05:08 PM
Dr G's Avatar
Re: My new dual setup
........My dad also got the idea to make custom "mandrel" bends to go around the frame by the trans. Turned out pretty good. I notched V's in the tubing at the angle needed, used a hammer to collapse the V on itself, and then he welded it all up. I'll post a pic of that too.
Nice one, I like the set-up onebinky. It's nice and simple, looks as though it's be quite easy to replicate. Not sure about how it would go with SFC's though. Will you be posting some pics of the H-Pipe in this thread once it's doen?. At what point are you thinking of placing the H-pipe?
Any pics of the notched 'V's onebinky?
Old Jun 9, 2004 | 06:18 PM
germ83's Avatar
Car: 1984 Z28
Engine: 305ci
Does anyone know where to get those ramps?
Old Jun 9, 2004 | 08:02 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Looks like a drive-on lift to me
Old Jun 10, 2004 | 01:28 PM
onebinky's Avatar
Sorry for the delay, I just got home.
They're huge driveon ramps that my dad made out of some huge aluminum beams he got. They stand about 30" high IIRC. His email is farmerto@netzero.net if you have any q's for him. They're pretty cool
The third picture shows all the notched V's, it's all the welds that are right after another on the pipe right off the header.
I'm gonna try and pass the oval H-Pipe right under the trans X-Member. If I can't put it there, I'll have to take the HP loss because there is nowhere else for it to go.
I'll have to look into the NAPA gold series filter, I've heard alot of good on them. I read somewhere that the silver is identical, can you confirm that?
EDIT: one of the next mods I plan is some SFC's if I can find room for them. I think I can snake the pipe off the side of the rear subframe, bring it forward and over the exhaust, and weld it to ther normal spot on the front. Sounds alot trickier than I think it'll actually be once I get into it.
Old Jun 10, 2004 | 04:34 PM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
I don't know if the Silver is the same as the Gold or not, but the price difference is pennies. I have a good buddy that works there and he doesnn't ever sell me anything but their top shelf stuff. If I'm doing something, I'm going to do it with the best parts available, first.
When you try to get your subframes in there, I want pics. If you can get a set of connectors in there, and have the exhaust there without bottoming out on everything, I'm next in line. I want to run the pipes through my ground effects and out right in front of the rear tire.
Old Jun 12, 2004 | 10:44 PM
CamaroEFI's Avatar
are those the $119 Hedmans?..if they are, those are the ones i have. right now all i have is the headers and Hedman 2.5" extensions. i have them pushed up as far as they will go and i still scrap on high speed bumbs and some drive ways. its also way too loud. i don't like how you can see the pipes hanging down neither. if someone would make a nice, custom trans. cross member (kinda like the Mustangs), i think they could make a good profit....all i can think of right now is using oval tubing but i still don't think that will help much cuz i plan on lowering my car.
Old Jun 12, 2004 | 11:27 PM
onebinky's Avatar
I think mine were like $134 from summit shipped, probably the same ones. I haven't had any issues at all with mine yet though.
Old Jun 13, 2004 | 01:04 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Third and last.
looks a little close to the brake lines.... that's one of my fears of switching to long tubes....
hmmm, maybe a nice custom heat shield would take care of that.....
Old Jun 20, 2004 | 09:14 PM
onebinky's Avatar
Here's a ground clearance shot for you fellas who were interested
Old Jul 28, 2004 | 12:34 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
I'm stealing your idea. thats awesome, exactly what i want todo, but replace the mufflers with glass packs. So its extra loud. Hehe.
Shane
Old Jul 28, 2004 | 03:33 PM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
uh...how is it in a stop ~n~ go type traffic? doesn`t your seat get hot?
Old Jul 28, 2004 | 05:06 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The floor of the car probably gets heated up more by the transmission than by the exhaust.
Old Jul 28, 2004 | 08:59 PM
onebinky's Avatar
Shane
That's fine, but I charge a $20 'Idea' fee. Paypal it to me
Because of the way the subframe is setup, there is at least a few inches between the floorpan and the muffs there. So like apeiron said, no issue there either.
Also, no issues with the fuel/brake lines. It only intersects the lines once, and it's far enough where it's not a safety issue. Also would be negligable performance difference in fuel temps. Couple degrees tops.
Bubbajones_ya
Jul 6, 2024 08:32 PM
customblackbird
Oct 1, 2015 04:30 PM
R13_Braz
Sep 18, 2015 05:00 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
