How many hours should it take to install new header gaskets
Old Jun 9, 2004 | 09:17 PM
yzarcem's Avatar
Car: 82 Camaro; in process of resto
Engine: 350 4bbl.
Transmission: 700R4 with B&M Lockup
Axle/Gears: Moser 28-spline axle; 3.23 gears
I'm debating doing it myself or hiring it out. I'm afraid that I don't have the time to do it myself. Just asking for approximate time...I don't want to get ripped off. Where should I go for this...muffler shop or a well-rounded mechanic?
From posts I see that 9 hours is way too long (thank goodness). I do have AC (hopefully they won't have to let out the freon just to replace the gaskets) if that makes any difference.
Any guesstimates are appreciated.
Thanks!
Old Jun 9, 2004 | 09:25 PM
84firebird383's Avatar
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
less than an hour, but you can plan on a shop charging you book rate
Old Jun 10, 2004 | 12:44 AM
level's Avatar
Car: 1987 transam
Engine: 383 /w superram
Transmission: 700r4 /w 2800rpm stall
took me about two hours the passenger side is EASY to do.. the driver side is a little harder you have to remove brackets and the last bolt closest to the firewall is rather hard to get at
Old Jun 10, 2004 | 01:18 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
^ What they said. Passenger side sucks though. Drivers side was cake. Atleast with my car...
Old Jun 10, 2004 | 08:19 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
if you've done them before or are a good mechanic, under a hour.
if you never work on cars... who knows? ive seen people on here take a half hour job and streach it for days.
Old Jun 10, 2004 | 09:51 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
Took me about 20 minutes, but I guess it depends on what you have.
Old Jun 10, 2004 | 10:20 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Took me 15 minutes to do both sides. I also don't have the AC in my Z any more so it took freakin longer to remove the clips off of my stage 8 bolts than to put the gaskets in.
Old Jun 10, 2004 | 03:17 PM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
Well I put exhaust manifold gaskets on yesterday, took me about an hr to do both sides, and that's counting the time it took to modify one of the gaskets. The felpro gasket set i had, came with the spot that slides of one of the end bolts to hold it in place was filled in so i had to cut it out with tin snips.
1992 Trans Am
May 10, 2023 07:19 PM
mdtoren
Aug 23, 2015 12:52 PM
NinjaNife
Aug 23, 2015 11:49 AM
mdtoren
Aug 16, 2015 05:45 PM
drathaar907
Aug 6, 2015 04:20 PM
