hedman y pipe and shorties dont match
85 camaro berlinetta 305 I hooked up the y pipe to the passenger side and when i go to hook up drivers side attachment falls just short of header anyone else have this problem?? thanks
Car: 89 Camaro RS
Engine: 305 TBI
I have the exact setup and the y pipe comes with an adapter to fit the drivers side header. Check your equipment again, it should be there with a separate clamp.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You have to loosen or unbolt the other side first, then it should fit. It just needs to bend a little.
Car: '93 S10 Short bed standard cab
Engine: 383 Stroker
Transmission: 92' stage 2 700r4 w/3600 stall
I had that same problem man. My passengar side fit but the drivers side wasn't long enough. I had to have a piece of pipe added so it would fit. I have a '67 oil pan on mine without the valley for the exhaust in it. That is why mine didn't fit. Do you have a valley in yours where it runs under your oil pan?
Car: Camaro
Engine: lt1
Transmission: 4l60e
Axle/Gears: 3.27 9 bolt
Does anyone happen to have a pic under the car of the y-pipe connected to the headers, because my hedman y-pipe looks like it wont even come close to fitting my headers. Looks almost if my exhaust would be coming out the front of the car but I havent had the pipe under the car up to the headers yet. Thanks
1Aauto
Sponsored Vendors
Sep 13, 2017 12:58 PM
[GA] Shorty headers
Night rider327
Sep 16, 2015 02:20 AM
