Can I use high temp RTV to seal band clamps?
Old Jun 14, 2004 | 06:43 PM
Mike89GTA's Avatar
Hey, has anybody ever put high temp RTV under a band clamp to get it to seal better? It was sealing perfectly but I had to remove it and I guess I didn't get it back on in the same position and now it leaks a little bit.
Old Jun 14, 2004 | 10:12 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Why not just spend like $15 and get it welded?
Old Jun 14, 2004 | 10:19 PM
Mike89GTA's Avatar
Because then I won't be able to remove the exhaust from the car, which is nice to be able to do when changing the clutch etc..
Old Jun 14, 2004 | 10:39 PM
Air_Adam's Avatar
Ok, I see what you're saying... but no, I wouldn't use RTV. I tried that, and it blew it all out in less than a week. Maybe try that exhaust patch tape under the clamp. That would work much better.
Old Jun 15, 2004 | 08:21 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
permatex ultra copper
not another brand of ultra copper
not another type of permatex
Old Jun 15, 2004 | 08:22 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
looks like this:
Attached Thumbnails Can I use high temp RTV to seal band clamps?-ultra-copper.jpg
Old Jun 15, 2004 | 08:49 AM
darbleinad's Avatar
Car: 84 Trans Am
i have used that on temporary exhaust connections to seal them up when welding wasnt an option and it works well. i always had to clean it off when i made a permanent connection, never had it blow out. i agree completely, the Permatex Ultra Copper is the stuff to use.
Old Jun 15, 2004 | 04:09 PM
hot86z-28's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 700R-4
well u said you dont want to weld it but you want the seal of a weld, you could try JB weld. this part wont have much stress on it, however i dont know how easy it is to get the stuff off. never tried that.
Old Jun 15, 2004 | 09:04 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Old Jun 16, 2004 | 08:17 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
you can NOT use JB weld on a exhaust system.. or in any high heat area.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Linson
Sep 21, 2015 01:08 PM
86IROC112
Sep 11, 2015 04:04 PM
Stryker412
Sep 7, 2015 09:11 AM
85Special
Sep 3, 2015 04:21 PM
