what muffler will flow most look here!ok guys the maro in my sig is still at the body
Old Jun 14, 2004 | 09:42 PM
V6camaroman's Avatar
ok guys my camaro in my sig is at the body shop getting worked on so ive been driving my 87 bird thats got the 2.8 auto in it. i love the car and all but when i took it to the track the best i could get was a 17.17 at 78 mph. that is with stock exhaust manifolds, 2 1/4" pipe where cat was and a full 2 1/2" dynomax super turbo catback #17493. u name it and ive got it done to the motor too. it was just rebuilt about 55,000 mi ago with a slightly bigger cam, cai and full ignition mods. anyways i would really like to break 16's with this thing. i have a few mufflers at home to try. basically what im asking is from the mufflers im about to list which one will put me to 16's. ok ive got a hooker aerochamber 2 1/4" side inlet and center outlet, a flowmaster 40 series 2 1/4" side inlet and center outlet, and a 12" long dynomax 2 1/2" bullit muffler. which one will put me to 16's because if one of them can i will be putting it on.
Old Jun 14, 2004 | 10:33 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Personally i'd go with the flows, but that's just me and im sure others will disagree.
Old Jun 16, 2004 | 08:21 PM
2out_The_Left's Avatar
the flowmaster is prob the most restrictive of them all. the bullet is your best bet since its a stright through design.... on another note, i don't think cam and ignition mods is a fully decked v6. if you get some head work done, you'll cut 16's no prob with the exaust
Old Oct 20, 2004 | 02:34 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Did huge cam, underdrive pulleys. Heads and intake porting...have flowmaster...and pf&e headers & y-pipe... 3.73 gears, 2800 stall, transgo shift kit...blah, blah...
Car only hit 16.8. though this is with the 3.4...the tranny was sticking and the car was not hooking...So I would think there was some easy room for improvement...weight 3755...heavy!
Anyway I found the stock exhaust with only a flowmaster was too restrictive. I added a cut out and took it to the dyno. I gained a good 4.3 TQ & 8.2HP just from opening the cut out. Floored the dyno guy. Said people normally don't gain that much....
SOOOO in your case...
So I have a bad exhaust system. So I would think its the lack of head work and porting on your car. I've heard alot can be gained from just a good valve job! Rebuild the distrubuter & make sure it is shimmed right.
Also you said slightly larger cam...well mine is huge for a 6 and I had to bump up the timing to 19-20 to make up for the huge overlap. I can run on reg unleaded with no ping. try to see if anything is hiding in your timing. Don't go crazy. Adjust it one at a time and drive the car. If it pings back it off...
Old Oct 22, 2004 | 12:17 AM
sellmanb's Avatar
Car: '86 Berlinetta
Re: what muffler will flow most look here!ok guys the maro in my sig is still at the
the dynomax super turbo catback wont do crap until you get headers. the 2 1/4" pipe where your cat is needs to be 2 1/2" otherwise you're restricting your entire exhaust to 2 1/4".
Once you replace the 2 1/4" "cat" with 2 1/2" pipe, and put on headers (i have no idea where you could find headers for your car lol, Redraif may know) you should get a lot closer to the 16's.
Old Oct 22, 2004 | 12:57 PM
redraif's Avatar
PF&E headers 586-949-3400
Old Oct 22, 2004 | 01:17 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Muffler flow chart comparison
http://exhaustsoundclips.com/cfm.pdf
Old Oct 31, 2004 | 05:23 PM
yt500pmd's Avatar
Car: 1968 firebird
Engine: 400 pontiac
Transmission: th400
http://www.pontiacstreetperformance....p/exhaust.html
alot of information on exhaust
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Street Lethal
Aug 14, 2015 08:25 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
Exxon Limited
Aug 9, 2015 08:13 PM
