what type of exhaust for 118 mph in 1/4 mile
Old Jun 26, 2004 | 07:46 PM
84firebird383's Avatar
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
i was wondering what types of exhaust people are using on N/A motors running 118 mph or better in 1/4 mile
Old Jun 27, 2004 | 04:16 AM
vampiroc's Avatar
Car: Z28
very vague... engine size? rpms turning? these things are necessary. Vipers are running stock exhaust and trap that speed...
Old Jun 27, 2004 | 06:55 AM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
I run 118 1/4`s and I run thru two three inch mandrel bent pipes over the axle w/flowmasters
Attached Thumbnails what type of exhaust for 118 mph in 1/4 mile-zzz-006-web.jpg
Old Jun 27, 2004 | 09:53 AM
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
I have a 383 that used to run 118-119 mph in 1/4 mile in my 1980 z28(dual mandrel bent with x pipe). I put it in my 1984 firebird,same gears same coverter ,ect. but with a single 3 in flowmaster cat back with a mufflex y pipe i can only go 113.5. greezemonkey, i like the set up you have, how is ground clearance?
Old Jun 27, 2004 | 10:22 AM
ground clearence Is good!( bout 4 inches guessing) I rarely ever touch anything including speed bumps or driveways..It gets tight over the axle by the fuel tank though...from the side, Granted these pipes are on the outboard side of the frame rails but only because that`s where the hooker super comps dump at
Attached Thumbnails what type of exhaust for 118 mph in 1/4 mile-zzz-003forweb.jpg
Old Jun 27, 2004 | 10:23 AM
Attached Thumbnails what type of exhaust for 118 mph in 1/4 mile-zzz-005for-web.jpg
Old Jun 27, 2004 | 10:46 AM
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
Thanks for the pics and info greezemonkey. I have LT Supercomps too. I think i am going to try and duplicate your system.
Old Jun 27, 2004 | 01:05 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Ever try, just as an experiment, to run the car with open headers for a few passes? Posts like this always turn into single 3" vs duals and maybe we could get some clear evidence as to how bad single 3" holds back your average high-HP car.
Old Jun 27, 2004 | 02:44 PM
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
88IROC350TPI Ever try, just as an experiment, to run the car with open headers for a few passes? Posts like this always turn into single 3" vs duals and maybe we could get some clear evidence as to how bad single 3" holds back your average high-HP car.
I have not run it at the track open, but i have driven it open headers, and there is a huge differance in power. I did just install one of my dynomax bullets in place of the flowmaster.It revs more freely and feels better by the seat of the pants comparsion. I will race it on friday and see how much, if any differance the bullet makes.
Old Jun 30, 2004 | 11:35 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
On my 383, I ran 118 using Hooker Super Comps, dual High Flow 3" cats into a 4" Mufflex.
www.geocities.com/dzperf
Old Jun 30, 2004 | 04:18 PM
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
how loud is that 4" system? the 3" bullet i have on now is way to loud. I'm not goin got keep it on even if it gets me back to 118.
Old Jul 1, 2004 | 09:58 AM
HiTech5's Avatar
Engine: 383
Axle/Gears: 3.70
It is not too bad with the cats on. I have 2 set ups for my exhaust. One is dual 3" from the collector into dual cats into a
y-pipe right before the rear axle. The other is dual 3" from the collector merging into a y-pipe near the trans tailshaft.
The system without the cats is somewhat loud and does not have a good exhaust not at low rpms. But, at full throttle, it has a sound similar to a Nascar.
Old Jul 7, 2004 | 10:20 PM
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
I finally made it back to the track. changing only the flowmaster for a straight thru dynomax bullet, I ran a best of 116 tonight. taction was much worse also. Its starting to feel like it did in my z28. I dont think i will be able to get the same power i did with the dual 3 inch ,but its definetly close
Old Jul 8, 2004 | 06:17 AM
HiTech5's Avatar
Engine: 383
Axle/Gears: 3.70
84firebird383 - Have you tried pulling your front sway bar when running at the track?
Old Jul 8, 2004 | 06:26 AM
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
No. i have done that on other cars, but right now with the 26 spline stock rear end I don't want to hook that hard.I do need to get some frame connectors tho. I also run on street radials as i did on my old z28.
Old Jul 8, 2004 | 08:53 AM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
My exhaust is similar to greezemonkey's, but it runs under the axle. Works beautifully, only pain in the *** is jacking up the rear of the car is tricky since you need to jack it up by the rearend and not the frame as it will make the rearend rest on the exhaust pipes
Attached Thumbnails what type of exhaust for 118 mph in 1/4 mile-dualexhaust2.jpg
Old Jul 9, 2004 | 06:05 AM
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
That looks like a really nice set up Chris. I hadn't thought about going underneath the axel. I still have my dual x set up off of my 80 z28. I might start hacking it up to see if i can get to fit underneath my 84.
Old Jul 14, 2004 | 11:15 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
greezemonkey, do you have a part # for those flowmasters or happen to know how long they are? Im abonding my hooker lts, true dual x pipe setup in favor of slp 1 3/4 and something like ******* exhaust. it sounds ****ing sick on the little 305 with a cam, but ground clearance is killing me with the car lowered on a 25.7 tall tire
Old Jul 14, 2004 | 11:52 PM
25THRSS's Avatar
I trap over 120 with a single 3 inch exhaust, which is only temporary as I will soon have a 3.5 inch catback to match my 3.5 inch y pipe.
Old Jul 14, 2004 | 11:57 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Scary A 3" doesn't really become restrictive until you are making over 400 at the wheels.
Old Jul 15, 2004 | 06:03 AM
they are 40 series, the least expensive ones around 50 each..they are 13 inches long and 9 1/2 wide. I used a offset/center outlet on the passenger side and a center/center on the driver side..diff use a H or X pipe to tone em` down. I had a similar setup with the small blocks but it used a 2 1/2 pipe and muffler and the pipes ran in the trans tunnel never had any issues with ground clearence. Lowered cars and big pipes can be a real pain, the only spot close on mine is where the pipes go over the axle...thinking about getting that BMR relocal kit for the panhard brace.
Old Jul 15, 2004 | 06:25 AM
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
I put true duals on last night using parts I had laying around. Unfortunatley the only mufflers I had are 3" bullets that i had from a previous experiment, man they are just to loud.I just used the S pipes from my mufflex y pipe to go underneath my crossmember and the ran straight back and did a turn out before the axel.I am going to try and run it wednesday the 21st if I get back to 118-119 mph.
Old Jul 15, 2004 | 11:56 AM
Cars without tail pipes are louder on the inside than they are on the outside, if you could route it to the side or over the axle it would be more friendly on the inside of the car
Old Jul 15, 2004 | 04:02 PM
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
With the bullets the whole set up is about 2db maybe 3db quiter than open headers. If I keep true duals I will go with quiter mufflers and get some tail pipes, not to metion reroute the pipes into the drive shaft tunnel.Right now I just want to see if it will make it back to at least 118 mph.
Old Jul 16, 2004 | 01:44 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Run an X pipe to quiet it down. My vortec 350 with bullets and an x pipe almost traps 112 mph and is the quietest amongst my friend's cars.
Old Jul 17, 2004 | 08:49 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Just 3" duals no H/X pipe into Flowmaster 40 series. Ground clearance better than my old dual exhaust but now loud as helll!!
Should easily be in the 10's uncorked, just wanting to tune for max effort street trim right now.
Attached Thumbnails what type of exhaust for 118 mph in 1/4 mile-bird-pre-track-debut
Old Jul 23, 2004 | 04:15 AM
BaddAzzRS's Avatar
Car: 91 Camaro RS
Engine: SBC
well if your looking for options why not call spintech and order some of thier flat nascar pipe and 3.5 inch thick mufflers.They'd be much quieter than the bullets and offer great ground clearence and still benefit from 3" diameter pipe. Only drawback is this set up can get expensive.
Old Jul 26, 2004 | 10:20 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
Lets see. 406 SBC NA: edelbrock headers, non mandrel bent y connection, edelbrock single 3 inch cat back, 11.84 @ 117.8 mph. Full weight, air cond, roll bar, stock saladshooters, moser 9, it is heavy, etc Opened it up and ran 118.1 mph. I can't make sense of it, but that is what it did. (of course, I check the a/f with a wb sensor and it was the same open/closed) Hooker long tubes are on, waiting for y pipe.....
Old Jul 26, 2004 | 10:37 PM
IHI's Avatar
IHI
Alright, it's in the 10's with dual 3" and flowmasters at 122mph-nuff said
Old Jul 26, 2004 | 10:46 PM
Car: 1991 Firebird
Engine: 427 LSX
4600 stall and, 3 speed, race gas, etc. and are pushing it on street trim.....do you have a modifications to et list of how you worked the time down?
Old Jul 26, 2004 | 11:10 PM
IHI's Avatar
IHI
Full interior with stereo system, 4600 TCI 9" stall, 50/50 mix of 92 octane from BP station down the road and 110 octane VP from gas station by the track. What kind of mods to et list are you looking for? The entire drivetrain is new and bugs were worked out, some of the members from the board can vouge first hand at the kind of street car this is, oops I did take out he back seat casue the back of it was was hitting my cage and it looked gaay with just the seat cushions in there, other than that look at my weight and ask yourself, does that really add up to a stripped down race car? Plenty of pics/posts, etc...do some searching under the user name.
Old Jul 27, 2004 | 04:11 PM
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
I havent been able to get back to the track yet. Last Wednesday was cancelled because there was a chance of rain. Right now I still have the duals that turn out in front of the axel. The car feels faster but is much to loud. Assuming i can get back to 118-119 mph I will most likely go with oval exhaust for the permenant set up. I am also considering putting the 3" single bullet set up back on and seeing how fast I can get it to go. The one other differance is on the old camaro I had dash 10 fuel line from the tank to the pump. On this car I still have stock fuel line.
Old Jul 28, 2004 | 02:06 AM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
if i did the spintech exhaust with nascar mufflers and dual cats would my car pass cali emissions???
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
colton_carlson
Mar 8, 2019 12:21 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
jbd1969
Aug 17, 2015 07:06 PM
