headers?
Old Jun 29, 2004 | 09:31 AM
slp_firehawk's Avatar
headers?
hi i'm wondering what i should do about my exhaust. i have an 89 gta with a minirammed 383 with protopline heads and zz409 cam about to be installed. problem is the car is lowered either 1 1/2 or 2 inches (not sure) otherwise i would definately get hooker super comps, but i've heard they cause ground clearance issues. would like some help with is, the car has the duel cat option and i already have a slp 3 inch catback (was told that should be big enough but i'm not sure)
thanks guys
jason
Old Jun 29, 2004 | 11:52 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Which Super Comps, the shorties or the LT's?
There were some people recently whose 2055 y-pipe hung a little lower than necessary, apparently Hooker had a bad run on the y-pipes. Otherwise, if you tuck them up as much as possible, you won't have any more clearance issue than you would with any other system.
Old Jun 29, 2004 | 02:32 PM
i was talking about the 2210's i would love the look and sound of the long tubes but from what i've read it seems it lowers ground clearance considerably and since car is already lowered and is going to be somewhat a street car i'm guessing the long tubes are too low?
Old Jun 30, 2004 | 01:21 PM
Clemson327's Avatar
Car: 1985 Z28
Engine: 383
Axle/Gears: 10 bolt/3.73
If you get the 2210's there is a very good chance you will scrape on every speed bump with a lowered car. You would also have to either get a Mufflex y-pipe or a custom fabbed one to mate up to your 3" exhaust. I have heard a lot of praise on here for the Hooker 2055's. You should not have any problems with these if they got the problem fixed that five7kid was talking about. They will also bolt up to your existing exhaust much easier.
Old Jun 30, 2004 | 06:56 PM
shouldn't i get 1 3/4 '' primaries with a minirammed 383 though? or is it ok to go with 1 5/8?
Old Jun 30, 2004 | 07:55 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I'd go 1 3/4. 1 5/8 really doesn't become a restriction until about 400 fly horsepower i'd say.
Old Jun 30, 2004 | 07:59 PM
and only headers that are 1 3/4 are 2210 and slp right? so that leaves me the expensive slp's that don't come with a ypipe
Old Jun 30, 2004 | 08:51 PM
84firebird383's Avatar
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
I think the 1 5/8 hooker supercomp shorties would work real good for you, plus i hear the y pipe is better that the slp y pipe
Old Jul 1, 2004 | 06:48 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
i'd go with the slp 1 3/4" mine came with a y pipe and my car is lowered 1 1/2" and I havent had any problems with clearance...
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
