Exhaust wrap -> glowing collector?
Old Jul 19, 2004 | 07:25 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I put on some exhauste wrap on my SLP headers when I put together the 415cui. Now my collector on the RH side is glowing some, no much, could this be due to the exhaust wrap?
It is only glowing on the RH side, not the LH side.
/N.
Old Jul 19, 2004 | 01:09 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Sounds like the timing needs to be advanced.
www.geocities.com/dzperf
Old Jul 20, 2004 | 02:50 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
I'm runnig pretty advanced timing already at cruising (45deg) I will check my cat tonight to see if its glowing, maybe its clogged or something.
/N.
Old Jul 21, 2004 | 11:39 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
The convertor to the pass side gets real hot much quicker than the other plus my floor mat above the cat has melted....
Guess its time to buy new ones......
/N.
Old Jul 21, 2004 | 12:18 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
/N.
are you running ported or manifold vac advance?
if its doing it at idle, it could be because you dont have enough inital advance.. adding in vac advance at idle should help solve that.
if its doing it while driving around, you might want to have the advance come in sooner.
Old Jul 21, 2004 | 03:12 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
its a TPI engine so its fuel injected.
Idle 32 deg
Cruise 45 deg
WOT 34 deg havent tuned it yet.......
And it does not glow on idle only after a cruise..........
Old Oct 6, 2004 | 05:52 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Did you ever get this problem sorted out?
I'm having the same issue with my car at the moment.
Old Oct 6, 2004 | 11:38 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I'm curious to know whwat the problem was as well.
Maybe a toasted injector on that bank or something to make it run a bit lean on that bank?
Old Oct 7, 2004 | 12:30 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I am going to take a wild stab here and say it is the header wrap. Header wrap is basically insulation. It traps heat inside the exhaust and it would not be to far fetched if they glowed. header wrap is usually frowned upon because headers can be damaged (not desinged to run that hot) and oil and such can soak in them and cause fires. Take the wrap off and see what happens.
Old Oct 7, 2004 | 04:35 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
i had headers glow on me and it turned out to be the rockers holding the valves open. i loosened them and it was solved. this is the first time you fired the engine with headers and wrap correct? how about the first time the engine was fired with just Headers or did you fire it all new i.e. headers, engine, and wrap? If you ran the engine with the headers and then put wrap on then the wrap is your problem. If this is the first time you ever started the engine than i would say your problems lie with timing or adj valves (rocker arms).
Old Oct 9, 2004 | 12:18 AM
IBTHA1's Avatar
Car: 89 GTA WS6
Engine: 5.7
Transmission: turbo 400 shift kit
OK Hdr wrap SUX, It traps in heat and moisture it kills the life of a hdrs (coated or not ) by at least 75 percent,that is why there a only a few places left to get that JUNK!!!!, A $10 can of high temp hdrs paint will do you more justice,and most likely solve the overheating"red" glow anomoly!!!~
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
PurelyPMD
May 5, 2016 04:57 PM
bamaboy0323
Sep 12, 2015 07:14 PM
Accerrito22
Sep 5, 2015 09:34 PM
