Need y pipe help
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
Need y pipe help
i searched y pipe for a few hours over this board and didnt really answer my questions
how much would it cost to have a 3 inch y pipe made for my z28?
i have headers and a current 2 1/2 pipe
also how much total do you think it would cost to have a y pipe made and to put on a muffler and cat that i provide so all they would do is weld the stuff on and provide the pipe i got the muffler and cat?
just like ballpark numbers
i went to a auto repair place not really a exhaust shop but asking for a good estimate he said just for the y pipe it would be cheaper to buy new headers since they come with y pipe
Transmission: 4L80E/4L80E
You can get non-emissions-legal Hedman hedders with a y-pipe for a little over $200.
Anything else with a y-pipe will be over $300.
If your current y-pipe has 2-1/4" downpipes, it would probably be cheaper and quite adequate to just have the current "Y" cut off and one that goes to 3" after the Y welded in.
Otherwise, prices quoted on the board range from $65 to $300. Most custom y-pipes fabricated by muffler shops that have had pics posted here are pretty poor efforts.
Car: 1984 Z28
Engine: 5.7
if each side which is 2 1/2 goes into a 3 inch id be fine with that
heres what i got now
i cant afford a whole new set of headers just to get the y pipe
Ouch. That goes beyond ugly.
Two 2-1/2" (or even 2-1/4") into one 3" is fine. You don't need 3" downpipes.
Getting a decent one fabricated seems to be a challenge. That appears to be a muffler shop job (looks familiar for some reason). Getting it done by a performance exhaust shop that knows what to do will put you back in the mode suggested by the repair shop.
Car: 1984 Z28
Engine: 5.7
i got a friend that knows somone that ive talked to that knows how to weld and can have the shop on a saturday for me he said all i need in the piping (just get straight he said) he said they got a pipe bender ive seen his welding its pretty clean looking. but im just wondering if he will be up to the task of the weld job of y pipe
any opinions on how to make my own y pipe for best performance ill probally be using a 3 inch magnaflow cat (dont have one on the system i have now and a 3 inch in single 3 inch out dynomax super turbo muffler
Car: 1984 Z28
Engine: 5.7
well i was browsing the internet found a flowtech y pipe i dont know the outlet though no sites seem to have info on it its under 100 bucks 11102Y part number. im not positive it will bolt onto my headers thats the problem.
do you think i would gain anything from going to 3 inch with a cat or would a new ypipe and muffler and keeping the cat off be good enough??????
i dont wanna over do the pipe size so 3 inch custom y pipe cat muffler or new good y pipe not custom no cat new muffler ? would i notice the differnce i got about 250hp at the fly
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
The ypipe that came with my flowtech headers is only 2.5" after they join (going into the cat) which is smaller than my stock one (3") and the design is no better than stock. Not sure if it's the same one though.
The best way to fabricate one yourself is with pieces of 2-1/2" & 3" straight pipe, mandrel 2-1/2" & 3" bends, and a Flowmaster 2-1/2" to 3" Y. Your search should have uncovered one done in such a fashion.
Based on your photos above, you'll notice a difference even with a collapse bend (like the one at the shop you're talking about) fabricated y-pipe.
Car: 1984 Z28
Engine: 5.7
found what you were talking about
its about halfway down on this page
http://www.motorsporttech.com/fbody_exhaust01.asp
35 bucks doesnt seem too bad
so
60 for cat
30 for muffler
35 for y pipe thingy
3 inch piping????
2 1/2 inch piping i can reuse from current system
100 bucks welding
225+ 3 inch piping not to bad for a magnaflow cat dynomax muffler and a solid looking y pipe
thanks for the help guys u can contribute more if you like on around the price for enough 3 inch piping for a cars full exhaust
so
60 for cat
30 for muffler
3 inch piping????
100 bucks welding
Car: 91Z28 L98
Engine: HSR 350
If you need the mandrel bends, there's a guy on ebay that sells 'em pretty cheap under the name Ubendman. About $14 for 2.5" and $15 for 3".
Car: 1984 Z28
Engine: 5.7
thanks but the guy i know at the muffler shop has a pipe bender
if u know any cheap places to get model number Y250300A flowmaster y pipe collector that would be helpful.. ive found 35 bucks and then like 8 bucks handling fee and some free shipping
I replaced the Y pipe on my LG4 with a 3" (IIRC) Y pipe from a carbureted IROC. (A TPI Y pipe won't work). Again, IIRC, that replacement Y pipe is stainless steel. On a high perf engine I've been told that mod can be worth up to 30 horses.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Buy the Hedman Y-pipe, and chop off the main pipe right in the middle of the collector... where the 2 down pipes meet. You do this because the main pipe is only 2.5", but if you cut it in the middle of the collector, you can get a 3" outlet.
Thats what I did with mine.
Car: 1984 Z28
Engine: 5.7
well i got a exhuast place doing it all for me wed ill have pics that night and soundclips hopfully im sure on pics though
they are welding on this stuff and making me a y pipe and running 3 inch pipe
Car: 1984 Z28
Engine: 5.7
forgot pic
dynomax superturbo muffler ( i want somthing quiet i like that alot better then noise)
magnaflow hi flow cat
btw the muffler is HUGE
[Sold] Flowmaster exhaust system
Night rider327
Oct 9, 2015 09:25 AM
LT1Formula
Oct 8, 2015 08:34 PM
