Too many tubes
Car: 1987 Camaro Z28
Engine: 5.0, 305, V8, 4BBL
Too many tubes
If anybody has a stock camaro, that is carbureted, what are all of these tubes?!! Theres sensors, and tubes all connected to one another traced back to the carb. Then after about a mile of tubing, they lead to a canister. I took one of the tubes off, and there was gas inside of it. Emmisions?
What would i do if I wanted to change the Carb??? What were they thinking?
"I dont ask questions, it's a GM."
-Carlos
What would i do if I wanted to change the Carb??? What were they thinking?"I dont ask questions, it's a GM."
-Carlos
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
That sounds like the charcoal canister. You can remove it, but your car with stink if you do. Its basically just a vent for the gas tank that absorbs the gas fumes.
I was messing around with it today, and i unplugged one of the tubes from a check valve type thing, and gas dripped out of it. That was the line leading from the canister to a check valve. It looks to me like its taking gas, not vapor, or its taking too much?
Car: 87 Black Formula
Engine: Rollercammed Lg4
Axle/Gears: 3.23 10 Bolt Locker
The previous owner on my car trashed those rubber lines, and I can smell the gas every time I brake or stop the car, even inside the car with the windows shut. It sucks.
Car: 1986 Trans Am
Engine: 305 Carbed
Transmission: WC-T5
I took mine out.... I put a big nut in the line then clamped it down with thoose metal clamps with the screws.
I can smell nothing even with my nose to it.
Transmission: 4L80E/4L80E
And your tank is therefore not vented.
GangsteressRide, it is possible to get gas in vapor lines if the purge is not operating correctly. There should be a decal showing a schematic of the components and routing for the system under the hood of your car. If not, check the FAQ forum, I posted a pic of one such decal a little while ago.
I've often considered re-hosing that spider web to relocate the big valve at the front of the engine to another place, such as closer to the canister. But, so far I haven't gotten up off the couch long enough to get the necessary hoses from the parts store and take the time to actually do it.
Car: Trans Am
Originally posted by TonyP455
I have a vented gas cap
gixxer92
May 18, 2017 11:20 AM
no green
Jan 9, 2016 09:22 PM
