dynomax race bullet vs moroso spiral flow
Old Oct 3, 2004 | 07:56 PM
klumb15's Avatar
which 3 1/2 inch in/out muffler is better, the dynomax race bullet or the moroso spiral flow muffler?? they are both around the 40 dollar mark..
Old Oct 3, 2004 | 08:10 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i have the spiral flows and was told they're slightly quieter than the bullet mufflers. either way it's loud.
Old Oct 3, 2004 | 08:38 PM
klumb15's Avatar
well i was just gonna go with a 3 or 3.5 inch straight pipe, but i figured i might wanna have some backpressure...so i'm looking into something like these kind of mufflers...there isn't much of a performance difference is there??
Old Oct 4, 2004 | 01:09 AM
chio987's Avatar
Car: 84 Firebird Trans Am
Engine: 305 4bbl HO
Transmission: 700-R4, 3.73 rear
i'd have to say the bullet would flow more, there's nothing to them, it's straight thru. the moroso spiral has a spiral thingy in it
EDIT: the bullet is $10 cheaper, i might buy 4 when i do my duals so that would be $40 saved with the bullets....but...using 2 spirals might make it quiet enough to only need the 2.. something to think about
Old Oct 4, 2004 | 10:55 AM
SnkSknrZ28's Avatar
Car: 1988 Camaro IROC-Z
xpndbl3, are u running straight pipes, Xpipe or Hpipe? Got any vids or sound clips?
Old Oct 4, 2004 | 02:21 PM
xpndbl3's Avatar
Car: 1984 Z28
i'm running headman long tube headers with the S-bend extensions, into an H-pipe, then about 2-3 feet of tubing back into the spiralflows, and then ending in turndowns. I like the S-bends that summit sells because they are mandrel bent so the whole exhaust is either straight tubing or mandrel bent for maximum flow. I am going to read my digital cameras instruction manual to figure out how to do videos then i'll shoot you a video of it. It's loud when you open up the throttle but at idle it's not too bad. It is quieter than no mufflers, but definately isn't a flowmaster. If you shoot me a PM with your e-mail address I can send you something probably tomorrow. I can't host a video so I'll just e-mail it to you.
Old Oct 4, 2004 | 03:03 PM
klumb15's Avatar
send me one too.... Klumb15@hotmail.com
Old Mar 2, 2005 | 08:24 PM
meeklay812's Avatar
Car: '89 RS
Engine: 383 in progress
Transmission: TH 700-R4
I know this is an old post, but could you send one to meeklay812@yahoo.com
Old Mar 2, 2005 | 10:42 PM
xpndbl3's Avatar
Car: 1984 Z28
well it's snowing out so i'm not sending any posts until it warms up. you can hit me up in a month or two when the temp is above 30 for a high.
Old Mar 14, 2005 | 11:06 AM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
Dynomax bullets
My car has a catalytic converter so it muffles the sound a good bit. Here is a sound clip.
Sound Clip
Visit my cardomain page for info on my setup.
My Cardomain
Old Mar 14, 2005 | 01:33 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
The only way the bullets and spiral flow mufflers are too loud in my opinion is if you aren't running some sort of X or H pipe.
I am running dual 2 1/2" with an X pipe and 2 1/2" bullet mufflers, with tailpipes it was super quiet, without it is like any other street/strip car.
My friend has dual 3 1/2" with an X pipe and 3 1/2" spiral flow mufflers with no tailpipes, his truck is pretty quiet for what it is (12:1 solid roller 383).
Old Mar 14, 2005 | 03:28 PM
klumb15's Avatar
yea i was afraid bullets were gonna be too loud, so i started looking at mufflers...then i'm afraid its gonna be too quiet...but then again i don't wanna get in trouble with the cops every corner i go around...i have a pretty good eyesite for cops tho, and when ever i see one i just let go of the gas, so i can get away with a louder exhaust, but I'm afraid i'll get busted with something too too loud...i wish i could hear some bullets in person....i'm going to be running dual 2.5's out of LT headers, then dumped right before the rear axle through 90 degree turndowns kicked to the side a bit...you think it will be too loud if i run bullets? i'm not worried abotu having it too loud for me, i can withstand any exhaust, i'm worried about getting in trouble with it....what do you guys think?
Old Mar 14, 2005 | 07:33 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
just to let you know, your not looking for backpressure, backpressure is BAD, your looking for a way to control velocity, they're two different things.
i had the moroso's with no balance tube dumping right underneath the car and it was LOUD. now i have an h-pipe and went with a chambered muffler, much better. actually thinking of making it even quiter with some of the dynomax ultra-flow's, and they probably flow better.
oh, and for you ground clearance ****'s here some pics of the clearance i have. granted, it's *slightly lower than stock* (v6 springs all the way around and no spring isolators out back) but i have a 28" tire out back:
lowest point:
Old Mar 14, 2005 | 07:54 PM
PhantomFE3's Avatar
Car: 1984 Z28
Transmission: TCI Streetfighter TH350
Axle/Gears: 4th gen 3.42
you probably wont get the backpressure your looking for with the spiral flow mufflers, heres why:
thats the 3" spiral flow for my car, theres about a 1" open section through the middle, straight through no spirals..
Old Mar 14, 2005 | 07:59 PM
mw66nova's Avatar
Engine: 7.0L
my old 2 1/2" spirals, you can *kinda* see the spiral baffle in this pic:
Old Mar 14, 2005 | 08:06 PM
PhantomFE3's Avatar
Car: 1984 Z28
hey do you still have those 2.5" ones or did you get rid of em?
Old Mar 14, 2005 | 08:24 PM
mw66nova's Avatar
Engine: 7.0L
i still have them, but they have some 2 1/2" pipe welded to the inlet side. i can cut them down so they only have like 6" of pipe sticking out instead of the 3' they do now.
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
Damon
Sep 26, 2015 04:29 PM
JSDaddy189
Sep 26, 2015 03:50 PM
