Will This Work?
Old Oct 14, 2004 | 04:40 PM
1986sc's Avatar
Car: 92 Z28 92 RS Vert
Engine: 350 TPI 305 TBI
Transmission: 700R4 Auto (2x)
Will This Work?
Hooker 2055's to stock dual cats , then SLP Loudmouth cat back system???? Is there an adapter i can place on the y pipe that will fit the two dual cats??
Old Oct 14, 2004 | 05:37 PM
Kevin Vandevenne's Avatar
Car: 87 IROC
It may be easier to get the 2055's with the Hooker y-pipe and run a single 3" cat, rather than keep the factory dual cat setup. I have the same issue with my 91 GTA, and I want to retain at least 1 cat for emissions reasons. I will go with the single cat setup as it will be easier to obtain the parts i need vs sticking with the dual cats.
Old Oct 14, 2004 | 06:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The only "adapter" is to cut the "Y" off of the y-pipe and run separate tubes to each cat - just like the factory did.
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
