Ture duel idea
Old Oct 27, 2004 | 02:09 PM
MisfitZ28NYC's Avatar
Car: 85 Z 28
Engine: 74 350
Transmission: 5 spd
Ture duel idea
I was wondering if anybody has done this and if it would work. It seems too simple so that what worries me. First of all my car has a T 5. I want to do two long tube headers then bolt a set of Flow Tech purple hornies with turn downs right to the headers. Will this work or will there be things in the way and what kind of long tubes would be the best. I was in a previous post that said hookers were the best with the T 5. Which hookers long tubes are they then? Any thoughts would be appreciated.
Matt
Old Oct 27, 2004 | 02:14 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
well right off the bat I can think of 2 things that might be a problem: muffler clearance and exhaust leaking into the car..
Old Oct 27, 2004 | 02:34 PM
IROCFAST's Avatar
the purple hornies will not clear the crossmember
Old Oct 27, 2004 | 02:37 PM
Car: 85 Z 28
Engine: 74 350
Transmission: 5 spd
Thanks for the info guys. I am pretty much looking for a true duel setup with minimal custom work if thats possible.
Old Oct 28, 2004 | 10:53 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
a true dual setup with minimal custom work = a bad idea.
Old Oct 29, 2004 | 07:23 PM
Car: 85 Z 28
Engine: 74 350
Transmission: 5 spd
Yea I figured as much. Just though I would ask. 88Iroc I see in your sig that you have true duels and are in the Jersey area. how much did they cost and how complicated were they to have done.
Old Oct 29, 2004 | 10:38 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i have true dual exhaust on my car with an h-pipe using the hedman longtubes and the Summit Racing chambered mufflers.
headers>hedman x-tensions>h-pipe>summit mufflers.
you can't use the hedman lt's though with a t5. the hooker headers are AWESOME but they are somewhat expensive.
Old Oct 29, 2004 | 10:46 PM
Car: '89 IROC-Z
My old dual setup was homemade and just temporary. It sucked in my opinion. Horrible ground clearance and loud inside and out of the car. Just last weekend I went back to single 3" exhaust. May be a little restrictive but atleast I can drive around and hear myself think.
Old Oct 29, 2004 | 11:24 PM
onebinky's Avatar
Check out the dual exhaust sticky at the top of the forum. LOTS of pics, including 2 of my dual setups
I also am going back to single exhaust though. After doing 2 dual setups for my car because of header changes, I don't wanna go thru the hassle of making another one yet.
Old Oct 29, 2004 | 11:45 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
And the Board has a rule against using the tech forums for "dueling".
Banjos, pistols, exhaust, words - whatever...
Old Oct 30, 2004 | 05:32 PM
Car: 85 Z 28
Engine: 74 350
Transmission: 5 spd
I called up a local exhaust shop today that does a lot of muscle cars and they said that I would be better off ith doing a 3 inch single exhaust with short tube headers. They were sayin that it wouldnt be much of a diference from the true duels and it would be a lot easier.
gta892000
Aug 11, 2019 11:16 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
Ironhead38
Sep 7, 2015 02:26 PM
