Need opinions on dual exhaust
Car: 90 Camaro RS
Engine: 6.3L 383 V8
Ok after extensive research on robbie's ungodly long trues vs big single etc etc post I'm still undecided. Should I go with 1 5/8 LT 2 1/2" dual, 1 3/4 shortie 2 1/2" dual, or 1 3/4 shorties and 3" single? I'm trying to optimize clearance, price, and horsepower at the same time. I want my cake and eat it too Damnit!
Car: 77 Firebird
Engine: 454
Transmission: th350
Axle/Gears: 4.10
I would go 13/4 shorty to 2.5 dual for best power and ground clearance.With the shorty header you wouldn't have to worry about sacrificeing ground clearance to get underneath the crossmember, and with the dual 2.5 you would have to worry about a restrictive y pipe that would go with the single 3.
Car: 90 Camaro RS
Engine: 6.3L 383 V8
Which routing is the best? Should I go around the tranny and straight out the back or do like Willie and follow the stock locations? Any suggestions?
yea heres mine im selling..
https://www.thirdgen.org/techbb2/sho...hreadid=265983
2.5 with h pipe and flows...sounds good..
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Following the stock routing would give the best ground clearance. But unless you are well over 400hp, then whats the point? Duals routed properly will cost quite a bit more to have made, and will be much more complicated than a good 3" single exhaust. The 3" will support just as much power as a dual setup up to about 400 or 450hp, and it will be alot easier to have made and to live with, because the ground clearance will be better. You also only have to buy half as many parts (ie. mufflers) to make it too
As much as I like ******* setup, it would cost a fortune to have something like that fabbed up at your typical exhaust shop.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
