Any help or suggestions is greatly neede/appreciated
Car: 1990 Pontiac Firebird Formula
Transmission: 700 R4
Axle/Gears: peg leg
ok i am doing a swap in late winter....MIGHT be n LT1 crate motor, but i do have a question. I want dual exhaust, real dual. so i wanted to know if anybody knew of longtube headers that would fit my car also how does this setup sound: Long tube headers, cats bolted right to headers, hedman h pipe bolted right to cats, then at the end of the h pipe will be summit chambered long tube mufflers, then i will have a shop make me some tailpipes. Does this sound like it would work? The rear end of my car is slightly higher than the front so that will help, i will also tuck it up as much as i can for clearance. Any help or suggestions will be appreciated.
Axle/Gears: peg leg
well, they are going to be connected directly to the cats and the cats will be right into the h pipe, or is that not close enough?
camaroinmotion
Exterior Parts for Sale
Sep 2, 2015 08:25 AM
NinjaNife
Aug 23, 2015 11:49 AM
