what is the benefit of a full length vs. shortened exhaust???
Old Nov 19, 2004 | 09:17 AM
iloveslayer's Avatar
Car: 89 iroc 350
Engine: 350 tpi
what is the benefit of having a full length exhaust as opposed to having an exhaust that ends closer to my y- pipe I don't see how that would help or hurt emissions or be too loud so long as it is not a race muffler.
Old Nov 19, 2004 | 09:21 AM
Car: 89 iroc 350
Engine: 350 tpi
additional questin
also I would think that having the 1/2 exhaust would not only be cheaper but I would think making the air travel less distance would improve performance. is this true as long as pipe diameter and all other variables were similar??? how would this affect backpressure???
Old Nov 19, 2004 | 09:22 AM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
The thing I would worry about is with a short exhaust a lot of carbon monoxide will get into the car. When I got my z28 the kid before me replaced the cat with a flowmaster and that was it, it was unbelievably loud and I had to leave the window down all the time so I didnt die of CO poisoning.
Old Nov 19, 2004 | 11:03 PM
Car: 89 iroc 350
Engine: 350 tpi
I was thinking about getting turnouts and what if i tried to run it to right befor the wheels and go out and back?
Old Nov 20, 2004 | 09:29 PM
Metal's Avatar
weight, cost and space.
less piping = less weight, less cost and more room underneath.
Old Nov 20, 2004 | 09:43 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Dont forget about the sound difference that depends on the length of pipe coming off the muffler. For this reason I want to get a low profile muffler and have it dump right before the rear axle.
Old Nov 21, 2004 | 05:39 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
though I doubt yo uwould see much difference from this but shorter exhuast will change the resonace point of the exhuast a little higher helping out with the upper end rpm range
though again doubt you would see much unless you want to match you entire intake and exhuast to match that point
Old Nov 22, 2004 | 02:53 PM
mightymaro94's Avatar
the extra 4 ft of pipe doesnt make that much difference on the price, performance or space for that matter, you want space issues, i got 3 inch duals, not 3 inch caps, my pipes are 3 inch from the header to the tip, try gettin your local muffler shop to do that one for you, o yeah its aluminized also, no rust, ever ever ever, that aint cheap, and sounds better then most after market exhaust i have heard
Old Nov 23, 2004 | 06:34 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
lets see it mightymaro94
midge54
Dec 27, 2019 04:14 PM
tom1985
Apr 19, 2016 07:55 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
drathaar907
Aug 6, 2015 04:20 PM
