LT1 Header and Y-Pipe Reccomendation
Car: 84 TransAm
Engine: Vortec 383SBC
Transmission: T56, Stage 2 Ram clutch
Axle/Gears: 7.5 w/28 spline axles and 4.10 LSD
Well here it is, Since I've been searching for so long, I have found quite alot of info on LT1 swaps here, but my question on y-pipes still stands.
I'm doing a conversion on my 84 T/A. I have a full 95 9C1 Caprice doner car (LT1 Of course) and have most of the pieces to start swapping engine and transmission. (nice low milage replacement engine too... jelous yet? hahahaha!)
Anyhow, exhaust - Of course I'm taking the heads off for a home pocket port, and I would never think of putting the stock manifolds back on, but who makes the best y-pipe for these cars?
My exhaust is a Flowmaster 3-inch, and I haven't found a header manufacturer yet that will give me headers with a 3 inch y-pipe. I'm confused. Maybe I"m reading the specs wrong but shouldn't the exhaust exit off the collector of each header at the collector diameter, then merge into a slightly larger pipe (3-inch) that meets with my 3 inch cat and 3 inch pipe? All I'm seeing is headers with 2.5 or 2.75 y-pipe diameters.. I'm frustrated..
Any part numbers would be helpfull, I'm looking for shorties, but if anyone has any low-buck favorites for this swap. let me know.. I might have to have a custom Y-Pipe anyway at this rate..
Steve
Steve
Car: 84 TransAm
Originally posted by Z28*****
SLP 30005, or hooker 2055 will work fine.
Car: 82 Trans Am
Engine: LTX
Axle/Gears: 3.42 strengthed 7.5 inch
get the slp 1 3/4, or hooker long tubes if you can spare the pain..
Leaves some room for modification, I am kicking myself after a head and cam swap for not putting on a 1 3/4 system when I had the chance.
Car: 88 Camaro
Engine: L98 350
Most shorty headers, Edelbrock TES or the Hookers for instance, will come complete with the Y-pipe to connect to the three inch converter inlet in the stock location. The third gen headers will need/reguire some modifications of the air piping I'd guess.
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
IMO theres one way to go, and thats SLP 30005, however some say the hooker 2055's will work, i definetly wouldnt run the edelbrocks myself.
Car: 84 TransAm
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Originally posted by wallyj
This is my problem you see, the headers that come with the y-pipes are necked down to 2 and 1/2 before the cat, then open up to 3... that's a restriction.. hence my problem!
Car: 84 TransAm
Originally posted by ShiftyCapone
SLP, Mac, and the Hooker 2055's all merge 2.5 collectors into 3" without any restrictions.
Any preference on diameter of the primaries? some have suffested the 3/4 ones, but 5/8 seem to be the popular choice, and I belive that's what the hookers are..
Car: '90 RS
Engine: 377 LSX
Awsome, thanks for the reference, hooker's sound like they have a good name to them..
Car: 84 TransAm
I would go with 1 3/4" primaries if you ever plan on modding that motor. In perspective they only make a few sets of 1 5/8" headers for 4th gen LT1's with the majority being 1 3/4". That narrows you down to the SLP's as your only choice for 1 3/4" shorties. The Mac's and Hookers are a 1 5/8" and although they would suffice, the LT1 swappers will tell you to go bigger.
Car: '90 RS
Engine: 377 LSX
So should I go long tube then? Since price is a consideration, 1 and 3/4 tube long headers might be cheeper than 4th gen shorties for an LT!.. even with the cost of a custom y pipe..
Car: 84 TransAm
4th gen shorties won't work in a 3rd gen engine bay. What do you plan on doing with the motor? Long tubes are always the best route to make power but they come at a cost. Fitment and ground clearance issues are enough to drive most people crazy. The 3rd gen SLP 1 3/4" headers will bolt right up and kinda have a nice mix between the two. I would search about long tube headers before you jump into any project you are not fully prepared for.
I have been shying away from SLP meerly due to price (a bit high) but if the hookers don't do it for me, then I might have to spring for the big bucks SLP'S!
Anyhow, I'm going to have to wait until the snow lifts to start some of the initial work on the cars, and I'm getting kind of anxious.. Been reading the LT1 swapping pages here like crazy..
Getting excited.. The Caprice that this motor was in couldn't find traction on a dry day, I can hardly wait until that beast get's under the Firebird's hood! mmmmm, and the noise... The wonderful noise it makes at WOT!!!..
Nice..
Car: 92' RS Camaro
Yeah, I think hooker could make a lot of money with
1 3/4" Shorties with the 2055 y-pipe. (Minus ball flanges).
Better yet would be a 3" collectors into a 3.5" outlet. It'd be ready to bolt right up to a mufflex and not have the clearance issues that longtubes have. Oh well, one can dream!
Car: 93 240SX
Engine: LQ9
Yeah the SLP's are soooo rediculous, 399 from thunder racing and a little lower in the 3's elsewhere. Thats just rediculous compared to the 2055's at $375.99
Car: 93 240SX
Engine: LQ9
Originally posted by Chrome
SLP's are $499.- at Thunder Racing...
http://www.schochperformance.com/vie...tegory=exhaust
$365
Car: 92' RS Camaro
hmmmm, I must have been mistaken then. For some reason everybody thinks the SLP's are so much more expensive... I might be ordering from that exact place, heh.
Car: 84 TransAm
Car: '90 RS
Engine: 377 LSX
I can't tell if you are being a bit sarcastic, I asume that SLPs are the better header and you just proved they are cheeper? I'm confused..
Car: 84 TransAm
Header coating
He was refering to what you said here
You can get both for about the same price and the SLP's are the better header for an LT1.
I'm asuming you have to remove the "Shipping Paint" before you apply such coatings to the headers? Cost versus gain ratio? Anyone?
Car: '90 RS
Engine: 377 LSX
Re: Header coating
Thoughts on Header Coating? I'm thinking that the extra for the inside-out ceramic coating isn't in the budget, and i've heard of a quasi ceramic bake on finish that is possible at home, anyone have any thoughts? I even have access to seriously hot ovens at work (scuentific grade ovens that do 600 D Cel. +....
Car: 84 TransAm
Hmmmm, Sounds like a high Lustre chrome like finish is in order then... I just thought it would be a a good area to save some coin but I can't even find anyone who sells just the ceramic paint. I guess that's where the money is right? hahahaha... Thank *** for VISA!
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
Thanks.
jerflash
Sep 24, 2015 03:11 PM
mygta87
Sep 14, 2015 10:36 PM
