Fabbing Y pipe. Are twin 2" pipes enough?
Old Apr 10, 2005 | 04:21 PM
Andy Fanshawe's Avatar
Car: 91 camaro rs
Hi all.
Just about to fab a Y pipe from my shortie headers (unknown origin). I want to make 2 pipes to meet at the cat (long gone by the way), then join it to my 3" I pipe. Is a diameter of 2" enough from each header? What do you guys think? I'm scraping everything at the moment, so this needs tucking in well.
Thanks for any reply.
Andy.
Old Apr 10, 2005 | 04:59 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
I'm no expert, but..
well a 2" pipe will have 3.14 sq. inches of flow. Times by 2, you get 6.28. A single 3" pipe will have 7.07 sq. inches of flow. I think using 2" pipes will be a bit of a bottleneck. Maybe use 2-1/4" pipes?
Old Apr 10, 2005 | 05:11 PM
Mark1963's Avatar
Hi Andy,
two tubes 2.125" dia. have about the same area as one 3" tube.
Old Apr 10, 2005 | 07:35 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
2-1/4" would be much better.
Old Apr 11, 2005 | 08:52 AM
Mark1963's Avatar
You're right, but Andy said things were tight.
Old Apr 11, 2005 | 02:59 PM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
My hedman y-pipe uses 2.25" pipes off the headers and meets a 2.75" pipe where the cat is. It is tight, but even with the exhaust clamp inplace, it doesn't hit the oil pan. You should be alright. I wouldn' go smaller than 2.25", that seems to be pretty standard,
Will
Old Apr 11, 2005 | 03:53 PM
Car: 91 camaro rs
Thanks for the reply guys.
Space is tight because of the SFC's and the constant scraping going over any bump.
I have just bought a pipe bender that goes to 2 and a 1/4" at a push. So I am going to try large first and see how it goes. I will post some pics as it is going along.
By the way, what coatings do you all use on the Y pipes. I don't want to ceramic coat at this stage, so what is successful? I don't want it to look like a rusty hulk in 12 months time
Thanks again.
Andy.
Old Apr 11, 2005 | 05:59 PM
Air_Adam's Avatar
Will
I have the same Y-pipe. Mine will be welded under the oil pan though, no clamp. I've seen this Y-pipe on other cars before, and it fits great. 2-1/4" pipe shouldn't have any clearance problems under the car/engine.
Old Apr 12, 2005 | 12:04 PM
norcalz28's Avatar
I was thnking about having mine welded in as well, once everything settles in and what not. I had a hell of a time installing it as space was tight in the garage and I had pushed the piece off the pass side header too far into the y-pipe and I have to pull it back out and hold it while I attempted to thread in some bolts. But it does puff just a little right there so I may have it welded yet.
Will
LT1Formula
Oct 8, 2015 08:34 PM
tmork454
Sep 29, 2015 06:33 PM
