which one to get (muffler)
Old Apr 26, 2005 | 06:06 PM
UDAMON's Avatar
Car: Mazda Protege5
i aint no expert which is why im here so which is better?
dynomag 3" in / dual 3" out
or
v-force 3"in /dual 2.5" out
thing is i cant seem to find ANYTHING anywhere on the name "dynomag"
Old Apr 26, 2005 | 06:15 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
never even heard of it.....
Old Apr 26, 2005 | 06:34 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
"Dynomax" maybe?
Old Apr 26, 2005 | 07:01 PM
UDAMON's Avatar
Car: Mazda Protege5
im pretty sure it wasnt dynomax. although it almost sounds like it has to be... the other thing is i can find any 3" in dual 3" out dynomax muffler either...
anyways is v-force pretty good?
Old Apr 26, 2005 | 07:35 PM
Air_Adam's Avatar
I havent heard much about V-force, but I dont think I've heard anything bad.
I know Dynomax makes good mufflers... good performance, and a fairly 'stealthy' sound compared to others, like Flowmaster or Hooker.
Old May 5, 2005 | 10:46 PM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
Flowmaster is the biggest company...most money for research...best sounding in my opinion...
Old May 5, 2005 | 11:03 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
You'd think if they had so much money for research that they could produce a muffler that could flow decently.
I say skip both of those and go with an SLP muffler
Old May 5, 2005 | 11:54 PM
REALPOWER's Avatar
Transmission: Th350
Coming from someone with experience running 15's
Old May 6, 2005 | 12:01 AM
REALPOWER's Avatar
Transmission: Th350
If you have ever read any david vizard books, he explains how straight through (glasspack) style mufflers do not flow as well as flowmaster style mufflers that are chambered but without baffeling. This phenomenon exists due to the way the exhaust pulses. Frankly, Ive found that unless you are running over 400 horses, the type of performance muffler doesn't seem to matter as much as the diameter of the exhaust. This being said, choose whatever you think will sound better. If you like rasp, go with a performance muffler with baffeling (straight thru will be the loudest, obviously). If you like rumble, go with an open style chamber muffler such as a flowmaster.
Old May 6, 2005 | 02:26 PM
UDAMON's Avatar
Car: Mazda Protege5
so bigger = better?
Old May 6, 2005 | 07:06 PM
Air_Adam's Avatar
Originally posted by UDAMON
so bigger = better?
All else being equal, yes.
Old May 15, 2005 | 11:51 PM
86 sports coupe's Avatar
Car: 86 sports coupe-83 berlinetta
Engine: 5.0 in the sports coupe-350 in the berlinetta
Transmission: 700r4 in the sports coupe-turbo-350 with a 2500 stal in the berlinetta
Dynomax 3 inch in dual 3 inch out part # 17670 and part number 17536.
Old May 15, 2005 | 11:54 PM
anyone know of a muffler other than flowmaster and borla that has a 3 inch in and dual 2.5 out exiting on both sides?
Thanks Randy
Old May 16, 2005 | 01:43 AM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
my new exhaust that i just bought except mine is alot bigger 4-inch back to 3 inch dual outlets. Go Spintech!
Old May 16, 2005 | 03:16 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
glasspacks vs straight through mufflers are two different types of mufflers
straight through are just that straight through with a perforated core
glasspacks are a taper style muffler. larger at one end then the other with lots of little baffles in there that don't help performance out any. so yes I guess they are straight through just without the straight through performance
as far as flowmaster I still dont' see how they woudl flow better then a TRUE straight through muffler would. the little chamber in there I would think would slow airflow down since it now has to redirect itself around the the muffler. kinda like the old turbo mufflers just maybe not as bad.
straight through muffler would be able to keep exhuast velocity up or so my thinking tells me
Old May 16, 2005 | 03:17 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
so bigger = better?
within limits
you go too large and the exhuast isn't able to keep up velocity.
some ppl might say you lose backpressure which is hogwash since backpressure is the enemy. it's velocity you are losing
Old May 16, 2005 | 09:46 AM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
try magnaflow
Old May 16, 2005 | 01:59 PM
1gta2c's Avatar
Try Banks also.http://www.enginetechandfab.com/store/page49.html
Old May 16, 2005 | 04:09 PM
Air_Adam's Avatar
Thanks Randy
My Hooker muffler is just like that. 3" inlet at the front, and dual 2.5" outlets, one on either side.
Old May 16, 2005 | 09:54 PM
Ben85Z28's Avatar
Car: 1985 Camaro Z-28
Engine: LG4
Flowtech afterburner P\N 50363
Old May 17, 2005 | 06:18 AM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
how does the afterburner sound? at idle? high RPM's?
compared to other mufflers?
Old May 17, 2005 | 07:47 AM
anondude13's Avatar
He meant that for exhaust systems where the muffler is right after the headers, and a muffler can be used to take advantage of exhaust pulse waves. I doubt that any thirdgen has an exhaust setup like this. Even if chambered mufflers are better, that doesn't say anything about the quality of flowmaster. They still lose on the dyno time and time again.
As far as 3" in, dual 2.5" out crossflows:
Dynomax 17227
Flowmaster 43083
Hooker 21729
Magnaflow 14267
Edelbrock 5509
Old May 17, 2005 | 02:30 PM
Ben85Z28's Avatar
Engine: LG4
I don't know yet I just bought it and was about to install it probably this weekend. The main reason I bought it was because it was 3" in and dual 2.5" out (crossflow) welded case made of aluminized steel. There is nothing inside to burn and the price was reasonable for me. I hope I wont regret my decision. I'll let you guys know if it's worth it or not.
Old May 17, 2005 | 03:50 PM
Air_Adam's Avatar
I nearly got one of those too. I actually ordered one in at the parts store I worked at at the time, but never bought it. Its built VERY beefy though.. nice welds, heavy guage tubing and sheet metal... nice muffler. Can't comment on the sound though, never heard it.
The Hooker muffler I got with the catback I just installed is built just as tough, if not tougher (weighs a ton!! and has good welds all over) and the sound... oh man... its pure badass
The Hooker muffler has a nice feature too, in that the muffler inlet (3" btw) uses a 3-bolt header flange to mate it up to the I-pipe. No clamps, and welding is unnecessary. makes installation and removal easy too.
Old May 17, 2005 | 05:36 PM
REALPOWER's Avatar
Transmission: Th350
Dynomax 17227
Flowmaster 43083
Hooker 21729
Magnaflow 14267
Edelbrock 5509
Nope...straight from his book. Not just header mufflers.
Old May 17, 2005 | 05:42 PM
REALPOWER's Avatar
Transmission: Th350
Heres what he has to say. If it is to be mounted to the header, a glasspack will need a longer collecter. Thats all. The book this is coming from is a small blocks on a budget. Not race engines with header mufflers.
Old May 17, 2005 | 05:43 PM
REALPOWER's Avatar
Transmission: Th350
Old May 18, 2005 | 09:01 AM
anondude13's Avatar
I think an I pipe that goes down the car and over the axle is a long enough collector. Not to mention that the cat is going to be the first thing the exhaust interacts with in our cars. The paragraph you scanned basically says exactly what I was saying. If I were putting mufflers on the headers I wouldn't think twice about using flowmaster, but for this application I think glasspacks are more appropriate.
FormulasOnly
Jul 23, 2018 08:47 AM
cstrobel65
Sep 16, 2015 11:54 AM
