Looking for a hi-flow cat...
Old Jun 16, 2005 | 06:12 PM
oifish's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 TPI L98
Where would I find a good hi-flow cat that will fit on a stock 89 RS?
Old Jun 16, 2005 | 06:29 PM
BulliTooth's Avatar
Car: 1989 Formula
Axle/Gears: 9 bolt GW6
donno the part# but catco makes good high flow cats for our cars, try summit
Old Jun 16, 2005 | 06:35 PM
oifish's Avatar
Engine: 5.7 TPI L98
I looked at summit before and found:
http://store.summitracing.com/partde...4&autoview=sku
and
I'm pretty sure the second one is the type that will fit my RS, because it does not have a 3" exhaust, but I didn't see anywhre that it was a hi-flow.
Old Jun 16, 2005 | 06:37 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
There's a guy on ebay selling hi-flow cats for around $50 all day long. Check it out.
Old Jun 16, 2005 | 08:25 PM
oifish's Avatar
Engine: 5.7 TPI L98
What would the inlet/outlet be for a stock RS. I think is should be 2.25", but I want to double check.
Old Jun 16, 2005 | 08:46 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
The only way you'll know what you definietly need is if you crawl under the car and check.
Old Jun 16, 2005 | 09:46 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Don't worry about if it is high flow or not. A catco cat is better than stock but you are still plagued with the tiny 2.25" piping. A high flow cat won't make any difference when the exahust is undersized as dramaticaly as stock TBI cars come with.
Old Jun 17, 2005 | 09:15 AM
oifish's Avatar
Engine: 5.7 TPI L98
That makes sense, but I just wanted to make sure that the 2.25" dia. was the right inlet/outlet size for the cat.
Old Jun 17, 2005 | 10:31 AM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
CarSound... they are made very well.
Tremo
Sep 3, 2001 05:57 PM
pvknight
Jul 14, 2001 12:17 AM
zupmanZ28
Mar 30, 2001 05:21 PM
