82 Exahust Options
Old Jul 6, 2005 | 02:04 PM
ck76239's Avatar
Car: 1982 z28, 2007 Silverado
Engine: 350 Chevy, 10-1 CR, Comp Cams 270h
Transmission: Th350,
82 Exahust Options
I Have an 82 Z-28, and I'm confused about my exhaust options...
I have a 305 in it now, but have a 350 in the works for the not so distant future. I want a single exhaust (maybe 3") to a single inlet, dual 2.5" outlet. I want the muffler to pretty loud, as the car is not my daily driver....
I'm uncertain if I will go with headers at this point, but if I do, I'm thinking shorties...
Also, the previous owner had removed the cat, and the air injection. I may put the cat back on to be legal, but not the smog stuff.
I was looking at several kits from flowmaster in the PAW and Summit catalogs, and most say 86 & up, or 83 & up.... Could not find a single 82??? What is the difference???
Thanks!
Old Jul 6, 2005 | 02:52 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
'82 didn't come with the single inlet/dual outlet muffler. That why aftermarket stuff is for '83-92 or whatever. Those systems should fit just fine though.
I reccomend the Hooker system for '83-85 L69 cars
Old Jul 6, 2005 | 10:51 PM
savagevulcan's Avatar
Car: 82 Trans Am
Engine: Pro Flo Injected 355
Transmission: BW Super T10 4 speed
Axle/Gears: Ford 9"/3.50
i agree with airadams recommendation.
i recently purchased that exact kit and had an exhaust shop cut the bent part and the flange for the cat off and run tubing from the y pipe to the cat back.
it is a very nice system. It is relatively quiet at idle but when you step on it, the hooker really screams for all shes worth
Old Jul 7, 2005 | 11:11 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Decide what you're going to do about headers, because that is an important aspect of the choices.
I would recommend starting at the front and finishing at the back with '86-'90 TPI single-cat application parts. Hooker 2055 headers, Catco 9118 cat, and whatever cat-back for the same application would all bolt together and fit your car (minor hanger modifications may be required). That is a good flowing 3" system that would easily support a 350.
(By the way, "'82 didn't come with the single inlet/dual outlet muffler" isn't completely true - the V6's had that type of system... )
Old Jul 7, 2005 | 12:11 PM
ck76239's Avatar
Thanks for the good advice.
I looked up the hooker 2055 headers, and they have the Air injection stuff on them, which I do not need, since I don't have the parts anyway, I couldn't put it back without a lot of $$$
Which leads me to these headers, no air, but they do have the port for the o2 sensor, they are flowmaster 16102
http://store.summitracing.com/partde...102FLT&FROM=MG
Any thoughts?
Old Jul 7, 2005 | 12:43 PM
five7kid's Avatar
Hooker 2055 A.I.R. tubes: Chop them off, weld them shut. Very easy to do (ask me how I know).
Flowtechs: Small primary tubes, small y-pipe, thin tubing material, poor quality. Price not low enough for what you get. Would be okay for an unmodified 305, okay for a low RPM torquey 350, if you can get by the leak problems that are sure to develop. A good temptation to avoid.
F-body-fan
Jan 12, 2023 01:49 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
gixxer92
May 18, 2017 11:20 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
