need help choosing headers
Old Aug 15, 2005 | 02:41 PM
  #151
DanTheMan_smlk's Avatar
ok i just went to the auto parts store and the guy was freakin out that i wanted 94 suburban wires....he said they wont fit. Is this true? He called someone and asked about wires for a "small block with headers" and then went into the back and came out with 46 dollar wires. Does that seem high price for plain old wires?
Old Aug 15, 2005 | 03:09 PM
  #152
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Those where probably universals. I use 'em. lot easier to get a clean install. You cut to lenght and terminate the wires yourself with either a crimper or pliers/screwdriver. Prefer my MSD crimpers to the manual method, though.
Old Aug 15, 2005 | 03:19 PM
  #153
they werent make your own wires, they were completely assembled wires
Old Aug 15, 2005 | 03:34 PM
  #154
Car: 88 Camaro SC
Engine: SFI'd 350
Hmmm... to my knowledge there arnt really fully assembled wires that will work as every set of headers and setup are a bit different.
Old Aug 15, 2005 | 03:45 PM
  #155
do plug wires have to be a specific length for the cylinder it was meant for? Could i put a long wire in the place of a short wire?
n00b here
Old Aug 15, 2005 | 08:49 PM
  #156
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
the moron of course said they wont fit... because he is a moron..
Dan.. for the last time... I AM USING THE 94 SUBURBAN WIRES!!!!!!!!!!!!!!!!!!!!!!!
do you think they dont fit on my car?????????
good lord man.. do you ride the short bus to school??? i mean honestly?? you dont listen to a thing we tell you..
Old Aug 15, 2005 | 10:44 PM
  #157
BT283's Avatar
Car: 1991 Camaro RS, 1993 Camaro Z-28
Engine: what engine, LT1
Transmission: did it come with one, 4l60
Axle/Gears: They spin (most of the time)
Sorry to jump in people, but DAMN!!! Listen to what they say dude, they know what they are talking about. If you would have just jacked the engine up you would have had the headers in 2 weeks ago. The good people at your (and any ones) local parts store dont know S**T!! You will find this out if you ever do a older model 350 swap in a 3rd Gen. And you would you lose your AC if it works, it is a everyday car correct??And you dont care about performace, correct?? Trust me it sucks sweating!! And dont be afraid to unbolt things and put them back together, it helps you become more knowlegable working on cars, how do you think most people learn how, they just jump right in. Just listen to what these people have to say, PLEASE!!
Old Aug 15, 2005 | 11:08 PM
  #158
lol, i couldnt stop laughing at the short bus comment
i got the wires anyway at another parts store cause the one i first went to didnt have the fan switch. They fit fine, i forgot to update..... What if the wires are longer than stock? There is one spark pluq wire that is short and touches against the header tube, i could re-route it using a longer wire...i can do this without any negative effects right?
SHORT BUS!!! i did get a 3.56 GPA in hs, so im not totally stupid, just worried about my car
Old Aug 15, 2005 | 11:14 PM
  #159
BT283's Avatar
Re-routing it would be fine but you could go get a fiberglass heat boot that slips on the header so the plugs wouldnt get burnt, click on my sig and look at mine for an example.
Old Aug 15, 2005 | 11:17 PM
  #160
yeah, i saw those in summit catalogue; im getting them. I need to get some heat shield too....is it bad that the headers are touching the coolant line that goes to the firewall? (it is black metal line next to the strut tower) Can i use exhaust tape from walmart as a heat shield?
Old Aug 15, 2005 | 11:21 PM
  #161
BT283's Avatar
i dont think it matters if it touches the coolant lines but i dont have a heater so i dont really know for sure, but exhaust tape should work, BTW the spark plug boots are the best $50 dollars i ever spent on my car!!
Old Aug 16, 2005 | 12:13 AM
  #162
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
hey i gotta give ya props Dan for tackling the install while being a n00b, even if you do have ADD.
Old Aug 16, 2005 | 12:23 AM
  #163
Old Aug 16, 2005 | 10:35 AM
  #164
BT283's Avatar
Yea im getting ready to put new headers on my car...PRAY FOR ME!! Know anyone who needs a set of Flowtechs..hahaha
Old Aug 16, 2005 | 02:50 PM
  #165
how do the wires go back on the starter? I want to be sure, i think i have it hooked up wrong. I touched the battery cable to the post and the car cranked, it was less than a second so i didnt mess anything up
Old Aug 16, 2005 | 02:59 PM
  #166
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Originally posted by Lo-tec
Be sure and disconnect the battery before this....and I would label the wires with masking tape.
...put them back where they were labeled. You did label them, correct??
Old Aug 16, 2005 | 03:01 PM
  #167
i did! i think i put the wrong wires on the wrong terminal
only one wire goes on the top small terminal, and 3 goes on the one under that? correct?
Old Aug 16, 2005 | 03:05 PM
  #168
Lo-tec's Avatar
The small wire goes on the small terminal, the big ones and the battery cable go on the big one.
Old Aug 16, 2005 | 03:07 PM
  #169
so thats 3 things on the big terminal
Old Aug 16, 2005 | 03:22 PM
  #170
Lo-tec's Avatar
ALL the wires on the big terminal, except the wire with the small ring (that one goes on the small terminal).
I thought you labeled these.
Old Aug 16, 2005 | 03:32 PM
  #171
Car: 88 Camaro SC
Engine: SFI'd 350
The only wire that doesnt go on the large center terminal is the solenoid wire. Its black/purple or some color other then red or orange. That one goes on the smaller side terminal closest to the engine.
Old Aug 16, 2005 | 03:43 PM
  #172
nevermind
Old Aug 16, 2005 | 03:47 PM
  #173
nevermind
Old Aug 16, 2005 | 03:51 PM
  #174
nevermind
Old Aug 16, 2005 | 08:35 PM
  #175
forget i asked anything
Old Aug 17, 2005 | 12:56 AM
  #176
oh snap!!! i got the maro running, its so loud. You can feel the car in your chest!!! im done except for getting pipe welded and heat sheilds
never thought the time would come
Old Aug 17, 2005 | 07:21 AM
  #177
Lo-tec's Avatar
hopefully next time it won't take 3 weeks!!
Old Aug 17, 2005 | 01:53 PM
  #178
lol, i do need help with this https://www.thirdgen.org/techbb2/sho...hreadid=315774 cause i had to drain the block
Old Aug 17, 2005 | 05:43 PM
  #179
i need heat shields for the wires. Wire seperators wont work for this because of the Edelcrap design. I need heat shield for the wires, not necessarily the boots.
i was thinking of getting THE-14250
more info and pics here!! https://www.thirdgen.org/techbb2/sho...hreadid=315832
Old Aug 17, 2005 | 08:26 PM
  #180
BT283's Avatar
those should work if you can keep them from sliding around
  #181
ok, it seems like ive been posting to myself latley. I started up the maro again and gave it a few revs then the smoke came. I get under the car and see that it is comming out of the headers, this isnt exhaust gas, its like buring smoke, and it was smoking after the car was off. I cant really get a smell out of it, i sniffed it in (saw the smoke going into my nose) and it didnt really smell like anything....
maybe its spray lube still inside there? Maybe its the coating?
its only comming out of the drivers side
Old Aug 17, 2005 | 08:30 PM
  #182
BT283's Avatar
probably just grease from your hands or antifreeze you may have gotten on them or something, nothing to worry about unless your HI-Tech coating is coming off, that would suck
Old Aug 17, 2005 | 08:52 PM
  #183
KiLLJ0Y's Avatar
Engine: 4.3 Turbo
Transmission: 4L60
its the inside of your new pipes... the heat is reacting with new metal.. usually sticks around for a few hours, but after a few hours of running it will go away
Old Aug 17, 2005 | 09:18 PM
  #184
BT283's Avatar
YEA
Old Aug 17, 2005 | 09:34 PM
  #185
this thing sounds like a shot gun when u rev it up
Old Aug 18, 2005 | 01:32 AM
  #186
what can i use as a cap for the AIR tubes? It needs to be able to screw on
Old Aug 18, 2005 | 07:21 AM
  #187
Lo-tec's Avatar
Put your old check valves back on, and then buy a box of rubber caps at autozone. They are made by HELP and come with 4 or 5 different sizes in one box (two of each size in the box). I think you need 5/8" ones.
Old Aug 18, 2005 | 03:14 PM
  #188
and they wont blow off?
Old Aug 18, 2005 | 03:17 PM
  #189
Lo-tec's Avatar
Nope. The valves are check valves, and are supposed to let air in but not exhaust gas out.
Old Aug 18, 2005 | 03:26 PM
  #190
five7kid's Avatar
Transmission: 4L80E/4L80E
Unless the check valves are blown. One of 3 of mine was.
Old Aug 18, 2005 | 04:27 PM
  #191
BT283's Avatar
HEHE got my headers on today, I did it in like 1 and 1/2 hours because i jacked the motor up, but i dont have any AC or Emissions crap to deal with either here is a pic
Old Aug 18, 2005 | 04:29 PM
  #192
BT283's Avatar
and here is the right side, this one just fell in
Old Aug 18, 2005 | 09:00 PM
  #193
the way your headers are designed makes them fit easier and lets you route the plug wires easier. I was cheap so i got Edelcraps. I dont care if they arent the best performance wise, i just wanted to do my exhaust all the way because i was taking most of the pipe off.
Old Aug 18, 2005 | 09:37 PM
  #194
BT283's Avatar
My headers where made to clear angled spark plugs. That is why they are easier to route the wires...i think BTW...Flowtechs suck compared to these Hedmans
Old Aug 18, 2005 | 10:57 PM
  #195
kalel21's Avatar
Car: 91 Z28, 86 Z28
Engine: 5.7 TPI, 5.0
Transmission: 4L60E/transgo shift kit
Just got mine!
Hey guys I just got my SLP headers today and will be installing them on the weekend. Would it be a good idea to buy the kit or should I just buy the parts I need at my local auto parts? Well here's a pic of them. There 1 3/4 with air.
  #196
Lo-tec's Avatar
BT283, your headers are easier to route the plug wires because you don't have AIR tubes. FWIW, I ran my wires over the top like yours with a set of SLP headers with AIR. The only way it worked was with old style perimeter bolt valve covers, moroso plug wire looms that bolt to the outer valve cover bolts by the headers, and a big f*n prybar to persuade the AIR tubes out of the way enough to run the wires down without hitting. Since I just recently cut the AIR tubes off and had them jet-hot coated, it's one less headache, and looks much cleaner. I have never done a set of edelbrocks and run the wires from the top...they just don't fit without touching a tube.
Hey dan, can we rename you short bus ? j/k
You can have a helmet for an avatar!!
Old Aug 18, 2005 | 11:00 PM
  #197
kalel21's Avatar
Car: 91 Z28, 86 Z28
Another pic
Here's another pic of the whole setup going in and the 3 inch electric cut off.
Old Aug 18, 2005 | 11:07 PM
  #198
Lo-tec's Avatar
Re: Just got mine!
Depends what comes with "the kit" and how much it costs. I thought they wanted over $100 to bolt their headers up.
You will need:
Exhaust gaskets-fel pro 1404
2 donut gaskets-walker 31500 or equivalent
A set of header bolts (3/8" with 7/16" head)
4 Y-pipe bolts and nuts-3/8"x2 1/4" coarse
A 30 or 45 degree bend to go from their y-pipe to your converter.
I would not use clamps on the y-pipe. I would mock it all up and weld it.
Old Aug 18, 2005 | 11:22 PM
  #199
Lo-tec's Avatar
Dan, I even found a pic for your avatar:
Old Aug 18, 2005 | 11:33 PM
  #200
gearrrhead's Avatar
Car: 1990 iroc
Engine: 350 tpi
the kit is not really nessesary.
you need headder gaskets, y-pipe dougnuts, heat shield for you fan wire, bolt for the dipstick tube, I recoment 12point 3/8 header bolts, it does not even come with all the bolts I would hvae included. I ended up getting 3 allen head 3/8 bolts for the locatins you are supposed to re-use you factory bolts.
I bought it out of lazyness. it was like $30. but like I said I ended up still getting some of my own hardware that I feel the kit hsould have came with.
