4th gen exhaust in 3rd gen
Car: 88 iroc-z
Engine: 5.7 zz4
Transmission: megaraptor 700r4
Axle/Gears: 3.73 10 bolt posi
can someone tell me how different is the 93-up cat back....
is the only diff thecat hook up or is the whole thing diff???
Car: 88 iroc-z
Engine: 5.7 zz4
can i install a 4th gen exhaust in my 88 iroc? are the hangers the same? the route the same? i really like the magnaflow kit jegs #
642-15620.....how diff is the intermediate pipe?? can i just cut off the cat end and fab up a new connection??
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
You also need a 45* bent pipe to make the turn to point the intermediate pipe at the cat if you have a single cat car, dont need one if its a dual cat car.
Car: 93 240SX
Engine: LQ9
Originally posted by jazzcat2001
but if you order exhaust for a single cat car and your car is currently a single cat car you are safe....minus the hangers of course?
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
imo it takes custom work which is beyond the skills of most DIY'ers. If you're handy with a torch, then more power to ya, however for most people it's going to take a trip to the exhaust shop and a couple of bucks, in the end making them wish they had just bought one for a thirdgen.
Car: 1990 iroc
Engine: 350 tpi
I just did this. I would hold off if I were you. pretty quiet. If you want I will make a sound clip for you.
I just ordered a spintech stainless muffler to replace the magnflow to try to wake it up a bit.
they way I did it was to eliminate the cat. bought a ball and socket joint from bassani. welded that to the header. then cut the i-pipe from the kit so I just need a striat shot to the ball and socket joint on the header.
of course you will have to mess with the hangers a bit. took about 3hrs so at a shop it would be around $150-$200 to get it done if you don't have a welder.
the kit is cheap though. $350 for 304 stainless exhaust. just a tad quiet for my taste and I have not cat and slp headers. I though it would be alot more agressive sounding.
