replacement quiestions
Old Aug 14, 2005 | 04:11 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
On my 85 Berlinetta, the pipe from the cat to the muffler is completley rusted, and holes keep cropping up. the muffler looks alright. I wanted to take it to a custom exhaust place and get a cat back, but my mechanic says its a waste of money. that pipe costs 44$, and he wants to reuse the muffler. Should I do this, or go with the aftermarket? Also, are there any aftermarket hi flow mufflers that will connect on the stock location to the origional exhaust tubing?
Old Aug 14, 2005 | 09:37 PM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
Any cat-back exhaust system should contain the new piping you need.
With a 2.8 you won't get much of a power gain, and the noise might get annoying with something aftermarket.
Personally I'd save the stock muffler and just put new piping on it.
Old Aug 14, 2005 | 09:50 PM
Toehead's Avatar
fair enough
sounds like that is the easiest route... ill take it thanks man
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
