removeal of emissions
Old Aug 18, 2005 | 07:34 AM
coreyfirebird's Avatar
Car: 1992 firebird
Engine: 305 tbi
Transmission: 700-r4
i have a 92 firebird tbi with 173000 miles and i'm thinking of removing the emissions system. i don't have emissions test in michigan. can i remove it and what kind of change can i expect from the engine. any horse power inprovements. i know i need to plug the holes on the exhaust manifolds and lose the cat. but is there any other changes i need to make
Old Aug 18, 2005 | 07:37 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Don't expect wild horsepower gains. You may actually reduce power by messing with the speed density system's brain (although that isn't very likely). Mostly you'll be reducing weight and clutter.
Old Aug 18, 2005 | 07:58 AM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
If you take out the smog pump and find a different belt you might gain a little power. I took it out to gain reliability.
Old Aug 18, 2005 | 09:29 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
You might feel a bit of a kick, if that. But The MAIN reason for taking that stuff out is to clean up the engine bay. Purley asthetics, and less stuff that can break.
Old Aug 18, 2005 | 04:46 PM
gscz28's Avatar
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
I took all mine out and made it look a lot better, didn't really see any horse gains.....I can give you a number for the belt but I think there is a article here that says the length you need..... I'll get back with ya when I get out of work
Old Aug 22, 2005 | 09:26 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You might not have emissions tests in Michigan, but removing or tampering with your vehicle's emissions systems is a federal offense punishable by a fine or jail time, if you get caught...
Old Aug 23, 2005 | 06:58 AM
Engine: LS3
Yeah yeah......thats what they al say....hehe. But honestly I have read that a bunch of times and have never herd of anyone getting in trouble. Not even a fine. I have not been around as long as other guys (21), but here in MA the smog tests are very strict and I have only herd of failed inspections and even then 20 bucks in the testers pocket is almost allways the cure.
I know that is the route that I am gonna have to take to get my 500 HP 383 91 Z28 back on the raod with a legit sticker. There is no way in hell this monster is passing emissions.
I say do what you want, cops are too stupid to figure anything like, what emission controls your car came with, out. Hell most mechanics can't tell. Who exactly is gonna be doing the arresting? Not trying to be a *** but after rambling for a minute, I really became curiouse. I would like to know who to watch out for (supposedly),
Old Aug 23, 2005 | 11:27 AM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I guarantee there is an anonymous tipline somewhere, I'm not saying its likely or even that they'll care, but it's always a possibility. My air tubes were cut and plugged very obviously and I passed MA inspection with a 20 year old cat.
I say get headers rather than plugging stock manifolds, its just a pain in the *** for no real gains.
Old Aug 23, 2005 | 12:34 PM
mdricken's Avatar
Car: 92 Camaro
I think cops might be able to give you a ticket for "faulty equipment" if you are missing an emissions device.
I got pulled over one time and the cop looked under my car by where the cat was to make sure it was there. Thankfully I still had it in then so no fine.
I think the "punishable federal offense" part is something the EPA puts in to screw auto shops. They go after the deep pockets, not individuals who couldnt pay a $1000 fine, let a lone a $20k fine.
Just follow the money trail.....
Old Aug 23, 2005 | 06:39 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I can understand why you would want to remove the AIR but is there any reason why you want to remove the cat? You won't see any real performance gain by just deleting it and you may not like the sound of your LO3 without it. Just food for thought.
Old Aug 24, 2005 | 09:47 AM
mdricken's Avatar
Car: 92 Camaro
Less weight Those things aint light.
Old Aug 24, 2005 | 10:32 AM
Car: 86 T/A
Engine: HSR 355
What's another 10 pounds on a 3200 pound car? I know it adds up and whatnot, but to stop pollution I'll limit my car just a bit.
Old Aug 24, 2005 | 01:21 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
When you remove the AIR system, you'd be wise to remove the cat as well, because the AIR system feeds the cat air to get it hot. VERY hot. Without the AIR system, it can't get hot enough to work properly, and will just clog up.
Old Aug 25, 2005 | 02:22 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
all the air system does is make the cat work before everything warms up. once the car is warm, the cat is warm enough. I fast passed IL emmisions with nothing but a cat.
Is this car daily driven? If i was driving my car every day i dont think i would take any of the emissions off. That equipment is there for a reason. I dont wana breath in those fumes! Its a TBI 305 anyways.... not a race car, it wont be any faster after removing that stuff.
Old Aug 25, 2005 | 02:40 PM
Engine: LS3
Well what SMURFN' Z28 said about the car not gettting any faster is true. If you aren't swapping that motor, just leave the stuff.
Only reason I took all my stuff out is the fact that I am changing every last thing on the car. It will be daily driven, but only 3 seasons.
Air pump wieghts nothin', maybe 3 lbs.
After that the rest must all weight less than a couple pounds and then there is the restirction of the cats, but that is a whole other thread, hehe.
Anyways, I am done.
Old Aug 25, 2005 | 07:21 PM
Air_Adam's Avatar
Old Aug 25, 2005 | 07:29 PM
five7kid's Avatar
Not true.
Old Aug 31, 2005 | 07:14 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Originally posted by dennisbernal91z
[B]Yeah yeah......thats what they al say....hehe. But honestly I have read that a bunch of times and have never herd of anyone getting in trouble. Not even a fine. I have not been around as long as other guys (21), but here in MA the smog tests are very strict and I have only herd of failed inspections and even then 20 bucks in the testers pocket is almost allways the cure.
Well, I guess I'm going to have to make an example out of you now, huh?
My 580 or so HP "monster" passed just fine. Infact, we ran it twice just to prove it wasn't a fluke, changing which pipe he put the sensor in, etc.
I suggest you learn a little more about cars before assuming something.
I take offense to that.
Can I say your too stupid to tune your car properly to pass emissions? How does it make you feel when someone calls you stupid?
-- Joe
Old Aug 31, 2005 | 07:16 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Your most definately on to something!
Very very recently, we did an exhaust on my buddies T/a. (speed density car). I spent some time tuning it for the stock setup (with lots of datalogging) and fuel + spark was dead nuts on.
After the exhaust, first few runs with the laptop and the thing was CRAZY leaning out. I couldn't believe how much fuel I had to add with the new exhaust. Now keep in mind, we're talking headers, catback, carsound high-flow cat, etc. But still. Talk about a dramatic difference..
Speed density def takes more tinkering to get it right, but when you hit the sweet spot theres nothing like it
-- Joe
Old Aug 31, 2005 | 10:30 AM
Car: 86 T/A
Engine: HSR 355
I know... but before its warm is when it starts plugging up.
My car was bought with stock cat and the AIR system removed. I've put 10K on it. The cat STILL isn't clogged so I doubt that's even remotely true.
Old Aug 31, 2005 | 01:43 PM
five7kid's Avatar
anesthes, with only cat removal, I'm not sure if that's enough of a change. With headers and full exhaust change-out, then definately you'll get into that situation.
As for cats clogging without A.I.R., urban myth. I ran my LG4 for 2 years w/o A.I.R., then put it back on when emissions test came up again, and it passed - I literally drove it from my garage after putting the A.I.R. back on, 3 miles to the test station, and it passed with flying colors.
A popular misconception is the A.I.R. is just there to get the cat warmed up. No, A.I.R. is routed to the exhaust manifolds during open loop operation because it is more effective there before the cat warms up. Once the system goes to closed loop, it has to be routed after the O2 sensor or it will give false readings there, and it is injected in the middle of the cat where it is most effective during those conditions (reducing CO, primarily, although it still helps combust unburnt hydrocarbons).
Old Aug 31, 2005 | 07:27 PM
Air_Adam's Avatar
It is true... didnt you notice how theres a hose going from the AIR system down to your cat?
Theres a reason thats there...
Old Aug 31, 2005 | 09:33 PM
88TATBI5.7's Avatar
Car: 88 TA
Engine: TBI 5.7
clogged cat
no it isnt true it is there to give more complete burn of the gasses the go through the cat, it is manly there because it is a cheap what to help the cars through emissions. if it was needed than all cats sold would have an air tube.
Old Aug 31, 2005 | 10:46 PM
Car: 86 T/A
Engine: HSR 355
The tube is there to keep the cat from getting clogged? WRONG! It's there to help burn pollutants which otherwise escape... they aren't trapped in your cat. I'd like to see one person that can prove the AIR pump removal ruined their cat becuase I've heard dozens of people that say it won't happen.
Old Sep 7, 2005 | 10:42 PM
deadhead1882's Avatar
Car: 82 El Camino
Engine: built 355
Transmission: T-56 upgraded internal
Axle/Gears: 10 bolt 3.42
im gonna run a cat WITHOUT air and gaurantee i wont have a clogged cat, and i know this cus it wont be the 1st time ive done it
Old Sep 8, 2005 | 11:38 PM
Air_Adam's Avatar
No, thats not what I said... that tube is there to get the cat hotter than it otherwise would get, which means it burns more of what goes through it.
Old Sep 10, 2005 | 06:51 PM
85blackberlinet's Avatar
Car: 85 berlinetta
Engine: none
Transmission: 700r4very soon t5
taking the a.i.r. off
i took all that crap off but my cat 5 years ago no power added but the cat is still fine
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
89fast5oh
Sep 8, 2015 09:55 AM
TBRays98
Sep 6, 2015 05:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
