Long tubes and duals
Old Oct 2, 2005 | 10:01 PM
Jman83TA's Avatar
Car: 1983 Trans Am
I finally found a way to run long tube headers and dual pipes on a 3rd gen without too many headaches. I used hedman long tube headers and had an exhuast shop bend a 'S' curve into a 2" pipe. I left alot of slack on the ends and cut to fit to make the bend directly under the transmission cross-member. I then just welded flowmaster 40 series to end of the pipes. It was very inexpensive to build and sound's awesome. You can then just end the tips of the mufflers even with the middle of the door, or just get some 30 degree bends and put some chrome tips coming out the side. And by the way, the clearance is suprisingly awesome.
Old Oct 3, 2005 | 12:44 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Which headmans?
ground clearance on my TD setup is terrible
Old Oct 3, 2005 | 08:50 AM
jimmy_mac's Avatar
Re: Long tubes and duals
A guy at our track used to have a set up just like that on his GTA. And he used 2 inch pipe also. I cringe at the fact I'm running 2.25 inch dual pipes with my shorties. I couldn't talk myself into running 2 inch pipes anywhere. But maybe they are far enough back with the long tubes that they aren't hurting flow to bad. Would be good to make some runs with the headers uncorked and then some with the pipes on to see. I'd really like to know.
Old Oct 4, 2005 | 03:29 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
have any pics?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
