Dyno:No cat vs. Cat
Old Oct 19, 2005 | 12:35 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Dyno:No cat vs. Cat
Found this looking around on the internet. This guy has a 355, LT4 Hot Cam, and a SuperRam with Trickflow heads and he did a comparison on his car. Go info...no cats didn't make a big difference at all...only 1 hp and a few ft pounds of tq.
http://dtcc.cz28.com/gta/dyno.htm
Old Oct 19, 2005 | 02:03 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Sounds about right. I wonder if he used a test pipe, or just used an empty cat.
I bet the gains would be even greater if he was using the stock cat.
Old Oct 19, 2005 | 02:04 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Modern day cats are no longer a bottle neck in a properly sized exhaust. That is why there is no reason not to run one (on a car that came with them to begin with).
Old Oct 19, 2005 | 07:21 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
VincentZ28 has been running at the track with no cats. He had to get his car smogged and left the dual cats on. Guess what? He had a new best et.
Old Oct 20, 2005 | 11:42 AM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Well it said a GM 3" cat so...I think it would be pretty much stock.
Old Oct 22, 2005 | 01:55 AM
MadMax350's Avatar
Car: 1987 Pontiac Fiero
Engine: 3800 Series 2 Turbo
Transmission: 4T60-E
Axle/Gears: 3.33
That is my dyno test referred to on the website. The test used a 3" in/out factory GM cat from a 95 GM pickup truck. For the no-cat test I installed a test pipe.
Old Oct 24, 2005 | 12:03 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
That's good info because I was wondering how much it makes a difference. I am going to switch from one cat to 2 high flow cats coming up and I don't have emissions so...its all good.
Old Oct 24, 2005 | 06:00 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I wouldn't bother honestly. If one only takes away 1HP and less than a handful of ft-lbs of torque, why spend double the money and buy two of them? I'd just stick to a single one...unless you're going true duals all the way back.
Old Oct 24, 2005 | 09:50 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
b/c i have two carsound cats already that my father wasn't going to use anymore so I am going to put them to use!! But i might gowithout them...don't know yet..but leaning more towards putting them on.
Old Oct 26, 2005 | 05:07 PM
87TPI350KID's Avatar
Car: 1987 IROC-Z Camaro
Engine: 5.7 350 TPI - SLP Runners, AFPR, MSD Goodies
Transmission: 700R4 - Shift Kit, Corvette Servo
Axle/Gears: BW 9 bolt, 3.27s
Remember not to only look at peak power, throughout the powerband it was worth a constant 5 hp and about the same torque.
Old Oct 26, 2005 | 07:46 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Yea, but the point is...it didn't take away much with a stock cat that wasn't a high flow unit.
Old Oct 26, 2005 | 08:04 PM
Car: 1988 IROC-Z
Engine: 427 SBC
I see what your saying. But I think it is different when your dealing with a 15 + year old cat (in thirdgens atleast).
Old Oct 26, 2005 | 10:59 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
No doubt...but a 95 cat is now 10 yrs old still. I have 1990 truck so its even old. I replaced it 6 years ago with a high flow unit from Catco but those flow teh same numbers as the new cats from GM. Now a high flow unit from carsound or random technology and you will pull the same numbers or more and be emission safe. But good points though all around.
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
