back header bolts
Old Oct 25, 2005 | 08:35 PM
Blkmaroman's Avatar
Car: 1998 zx9r
Engine: 899CC inline 4
Transmission: 6 speed manual
Axle/Gears: 15T front sprocket, 43T rear
back header bolts
does anybody have and tips on how to get to the back header bolts on the passenger side. ive got shortie headers on my 86 iroc and the back 2 on the pass side have got me stumped they came out and i cant get my hand back there to get them in i tried going up from the bottom and still no luck. my hands are too big, anybody know a good technique to get these in because im driving now without them in.
Old Oct 25, 2005 | 10:55 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
Allen head stainless steel 3/8" thread 3/4" length bolts. I can get my headers in and out in 5 minutes a side.
Old Oct 26, 2005 | 03:12 AM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
Might try taking the header off and rethreading all the bolts starting with the last two first. Don't tighten them down all the way, though... or else it will be impossible to thread the rest of them correctly. Tighten them down in a series, one by one, until all of them are completely tight.
My 2055s came with 7/16" bolts, so I used a combonation wrench to get at them from the top. The starter gets in the way from the bottom, and even if you take it out, it's still easier to get from the top. Just keep at it and you'll get it.
Old Oct 26, 2005 | 08:24 AM
Blkmaroman's Avatar
Car: 1998 zx9r
somebody also recommended using a piece of rubber hose that fits tightly over the header bolts, i think with all these ideas i can surely make one of them work, ill try and see what happens.
Old Oct 26, 2005 | 11:09 AM
Car: 86 T/A
Engine: HSR 355
Tighten the bolts in order from the inside out. Thread them all loosely, then start at the center 2 primaries and work out.
Old Oct 27, 2005 | 02:17 AM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
Or, you could just simply unbolt the trans mount to the crossmember and jack up the back of the trans. This will give you some clearance to tightened the back bolt.
Old Oct 27, 2005 | 10:57 AM
Blkmaroman's Avatar
Car: 1998 zx9r
i can get to the 2nd from the back header bolt and turn it, but when i turn it the bolt wont start for nothing. I have turned it for an hour and it will go sideways when i start turning it. I loosend the header up and still couldnt get it to start. Its hard getting to it and when i do the bolt wont start. This is probably the most frustrating thing ever on my car. I can rebuild a 350 and put it in my car but i cant get my back two heade bolts on, This sucks.
Old Oct 27, 2005 | 11:33 PM
Car: 86 T/A
Engine: HSR 355
Is there anything in the hole stopping the bolt from going in? Maybe just remove the bolts and install the rears first so you can change the angle of the headers so you'll have more room to work? There aren't really any tips to it, just grinding sockets so they fit in there.
1984HO
Mar 19, 2021 11:59 AM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
