Help Me Build A Custom Exhaust!!
Old Oct 31, 2005 | 11:18 PM
StocRoc's Avatar
Need help w/ the exhaust on my 86 Camaro. It has a ProCharged 350 running about 14#s of boost. Here's the problem, I have to use my Hedman shorty headers and Y-Pipe as well as a Spohn Crossmember for my T-56.
None of the exhaust shops around here will touch my car, and they don't know anything about performance. So, I will be building the system myself. Welding is not a problem, I just don't know what parts to get. I was thinking about ordering some of the pre-bent pipes from Jegs/Summit, but don't know where to start. Not sure what size to run, how to run it, and what muffler to get. The car doesn't have a cat. so that's not an issue.
Please help, and let me know if you need more info. on my setup.
Old Nov 1, 2005 | 07:04 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Well my friend, all I can tell you is that I am in the same boat. I have a 383, with a T-56 and 2210s, (hooker long tubes). I am going to go oval right away and then just run them straight back with only slight bends from heating the pipe. I too can weld, so any major bends I will just cut and weld. Then run some spintech "cruiser" mufflers that are only 2 1/4" thick. All tucked up as high as possible. Might not be the best for overla power, but def gonna flow and keep my clearance up there. Hope this helps.
go to www.drgas.com
www.spintchmufflers.com
later
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
formula_novice
Sep 5, 2015 03:58 AM
downsouthboy
Aug 29, 2015 11:29 AM
Dialed_In
Aug 20, 2015 01:45 PM
