Post Your Cut Out Pictures
Old Nov 26, 2005 | 01:42 PM
IROCtheRoad's Avatar
Car: 84 Z28, '15 Colorado
Engine: L69
Transmission: A4
Ok, I'm going to try this again. I want to get a cut out for my brother's 89 L03 for Christmas but I looked underneath and couldn't find a good place to put one. I was hoping ya'll could tell me and/or give me some pictures of where yours is. Thanks
Old Nov 26, 2005 | 02:52 PM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
just before the muffler which is actually too far back to make it sound good BUT it did make a 18 Ft/lb difference on the RW Dyno...
Attached Thumbnails Post Your Cut Out Pictures-camaronov2005-5-sm-cutout.jpg
Old Nov 26, 2005 | 03:09 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
right under the passenger seat in the "I" pipe, also equipped with a McCord Power Plate
Old Nov 26, 2005 | 03:23 PM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
thats the only good place to do it is where the cat goes, you have to do it before it , seems like a waste to do it after the cat. A lot of people do it after the cat since its easier . but do it before the cat , either remove the cat or move it in the middle , in the i pipe .
Old Nov 26, 2005 | 06:35 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Mine is a single 3" cutout, just after the Y-pipe. Its a perfect spot for it IMO, because its right near the outside of the car, so theres no crawling around under the car to uncap it, you can reach it easily from the side of the car. I used 9/16 stainless nuts because its easier to get them tight enough to seal well (compared to wingnuts). I just keep a 9/16 box end wrench in my glove box for when I want to uncap it.
Reddeath210
Oct 6, 2015 08:20 AM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
Linson
Aug 21, 2015 02:12 PM
LittleFranks
Aug 20, 2015 03:55 PM
dbrochard
Fabrication
16
Aug 19, 2015 06:21 PM
