View Poll Results: Mandrel bend or Custom bend
Mandrel Bends
100.00%
Custom U&J Bends Welded
0%
Voters: 11. You may not vote on this poll
Vote on Mandrel bent or Custom bent pieces
Old Jan 1, 2006 | 01:58 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
I have a custom fabrication shop locally that can weld U&J Bends
to make a complete Y-Pipe or another shop that have a mandrel machine.
If you had a choice what exhaust would you get taking into consideration: restrictiveness and looks.
Place Your Vote Above
1. Pieces of custom fabrication U&J bends welded together.
2. Mandrel Bent
Thanks for Input...
Old Jan 2, 2006 | 02:59 AM
RestoRoc89's Avatar
Car: 1987 Iroc-Z/1993 Z28/2011 Corvette
Engine: 350 CI TPI/355 CI LT1
Transmission: 700R4/D&D Performance T56
Axle/Gears: 3.27 9-bolt/3.73 10-Bolt
I would definitely prefer the mandrel bent route for several reasons. Firstly, considering aesthetics, the final product will be one smoothly formed pipe (as opposed to having many welds and possible tube distortion from the heat generated during welding). Cost and time are also a consideration. I've done work with CNC tube benders in the past and know that a competent technician can program, set up the tooling and bend a tube in far less time than someone could mock up and weld the shame shape from U- and J- bends. Moreover, using U- and J- bends would generate a significant amount of waste material, whereas the mandrel bent piece is the only material in question. Using logic, the mandrel bent y-pipe should be cheaper and better...however I know that isn't always the case as mandrel bender-equipped shops are few and far between, and tend to charge excessively simply because they can.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
dbrochard
Oct 3, 2015 12:43 PM
Linson
Sep 21, 2015 01:08 PM
FormulasOnly
Sep 6, 2015 10:42 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
