header paint / coatings
Old Jan 3, 2006 | 05:05 PM
nosvet's Avatar
Anyone have suggestions for a coating for headers? I'm cleaning up my Hooker Super Comps that were originally silver / nickel.
Anyone have experience or suggestions on what is the best method and product to use to try and restore them to original look?
Other then painting them with some high heat paint, best temp I could find was like 1200f I don't have any other ideas.
Thanks to all.
Old Jan 3, 2006 | 11:51 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
For DIY... www.techlinecoatings.com
Old Jan 13, 2006 | 07:57 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Use VHT Flameproof header paint. Put on a few good coats and when dry until they're flat black, heat them lightly with a mapp torch until the paint looks wet again and then let cool. Do this a couple times to cure the paint and it wont peel or flake. I don this on all of our dyno headers and they have lasted 5 years on the original paint.
Old Feb 23, 2006 | 08:28 PM
DustyJL's Avatar
Car: 91 Camaro RS
Engine: 3.1L V6
Axle/Gears: Stock 3.23 open diff
Would a propane torch work as well as a map torch?
Old Feb 23, 2006 | 08:52 PM
Dialed_In's Avatar
Yeah, just take a little longer. Heat them up until they look glossy, then let them cool. Once you get them on the car, if you see smoke shut it down and let them cool off.
Old Feb 23, 2006 | 09:10 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The key to getting the paint to work is the metal MUST be clean!!. Soap and water won't cut it. Take your headers to get sandblasted, have them use a slightly harsher grain, which will leave the metal a bit coarse, like whats used on industrial equipment, will be better here. Don't use the stuff that leaves it glassy-smooth. Then follow the directions on the can, and don't cut corners.
I did this, and except for being dirty, my headers look like I just painted them, and the paint is over a year old now.
Old Feb 24, 2006 | 08:01 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
I used POR-20.....
Old Mar 2, 2006 | 07:58 AM
dwint's Avatar
Car: 88iroc
Engine: 355 blueprint engine
Transmission: raptor built 700r4
Axle/Gears: 373
paint
vht has a new 1600 degree that works great i have 10,000 miles on mine and they look new.you have to bake them four different times and temps
Frozer!!!
Jan 19, 2024 04:55 PM
tom1985
Apr 19, 2016 07:55 AM
Dyno Don
17
Nov 2, 2015 11:43 PM
hectre13
Sep 8, 2015 03:38 PM
